solderdude
It has nothing to do with my subjective findings of tubes (I even design tube amps).
It's just the 'sound healing' properties you attribute to them are incorrect.
You can disagree with that, I don't mind.
Yes, tubes do clip differently (depending on the circuit design and purpose) but they do not 'change' an already clipped signal unless the tube circuit 'soft clips' way before the DAC does.
In that particular case the harmonic distortion rises alarmingly when measured so is easier to measure than to hear.
Yes, they do add harmonics in a certain frequency spread (I make use of that in my designs on purpose) but does not improve fidelity.
This too is highly dependent on the circuit it is in. One can make a tube amp with almost no added harmonics as well.
It just takes more tubes, lots of feedback and good transformers within the feedback loop.
Tubes may leave you with a 'positive feel' when listening to music though.
You just prefer a colored rendition in that case.
