WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
My inner skeptic tends to expect "diminishing returns", considering this is @1.500$.
@thread topic: IDK if metal is the best choice for IEM, because it adds weight and chills the ears, which can be pleasant or not, depending on the outside temperature.
@amirm in your conclusion you wrote "The MP145 is a nicely made, good looking IME which comes very close to approximating our target". Not sure if you meant "good looking IEM" or...
It might be there but would not count that it is looking at the graph. That is what 15, 16K? Do you think the measurement rig used can accurately measure what you are going to hear up to 16K?
This is a review, listening tests and detailed measurements of Truthear x Crinacle Zero:RED IEM. It was sent to me by the company and costs US $55. I was relieved that they are more mahogany/darker red than what the name implies. Compared to the previous Zero version, they are supposed to have...
Looks good, the only potential "risk" I see, IDK if the E1DA will be enough to power the "current hungry" RED.
Then again, hearing too loud is not advisable anyway.
I only listened to MP145 for the duration of the review (30 minutes or so) while I have been listening to E3 for a couple of weeks. I find the level of detail MP145 can produce, like some other IEMs, is incredible. At the same time, its sub-bass reproduction is not anything like what E3 can do. They are just different animals.
Thanks fr the review, I'm interested in this iem since it's launch curious to try a planar and rarely using full sized cans lately for various reasons.
From graphs it seems fairly balanced with smoother treble than other similarly priced planars, and you measurements confirms it.
Il probably give a try if it'll go available at amazon.it where i can possibly return it without hassle, iem's fitting is always a crucial point you can't know until trying, especially for a big one like this.
That is not what I said nor it is my point. My point is, what the graph says and what you hear might not be always the same. I think it is helpful to understand the limitations of the tool you are using.
It absolutely is enough. They aren't the easiest to drive iem ever but the 9038s (I still maintain the single ended D is better as you don't have to recable) is one of the most powerful dongles ever. Assuming nobody is adding any large eq peaks to the Red (or using the bass adapter).
