lowkeyoperations
- Joined
- Sep 13, 2021
- Messages
- 300
- Likes
- 293
The KH310s are good speakers, but you won’t get the best out of them- or any other similar sized monitor- without treating your room, or perhaps using sonarworks/room eq. You have close to 40dB between your peaks and nulls. That’s not feasible to mix on.
Questeds, PSI, whatever, won’t fix that.
On top of that you are trying to achieve two different experiences in the room. 1. Some mixing/composing and 2. Watching movies with a lot of bass.
I think you should return the KH310s while you can, unless you are prepared to install bass traps in all corners of your room.
Instead, try a sub with your existing monitors. Mix without the sub, or with it barely there. You need accuracy more than anything when mixing or every decision you make will be wrong.
When you watch movies, turn the sub up and sit in your favourite bass node.
