The initial idea (post 1) was to use CPU like clamps to ensure a good contact. Based on the answers I received, I will go for a mechanical attachment but not so sophisticated - some sort of clamp, but simpleri need to figure it out. I didn't draw the holes for the mechanical attachment in the PCB for simplicity. It is just a draft.
I don't think it is possible to DIY solder heat pipes, they might explode, I plan to use heat transfer tape at the amp side. At the radiator side, they sell radiators with holes for the pipes and a small side dent to refill with thermal paste:
The hole point of the project is not to use the enclosure as heat sink and make a multichannel amp as small as possible. If i see it is feasible, I will even 3D print the enclosure with the minimum parts made not of thermoplastic, what would give me a lot of design freedom. This is the main objective, see if it can be done.
Btw last night I was rearranging parts and am in 10x6.5 cm now, the big caps being the limitation at the moment.
I am still trying to figure out if I will need to operate the 4 amps in master/slave mode and if it is worth having the microcontroller for fail signal reporting and most specially for reset. Advice is welcome (there will be a microcontroller anyways to control the pem fan).
