Makes me wonder what Google could do with a serious budget to work with. Very good engineering here for $100.
The probably hire engineering grads who are well versed in the research, and haven't been corrupted by the traditional hifi industry.So I think there's a clear Harman/TooleSchool influence. Again, I'm just happy to see they're actually putting in the effort to use their massive resources and make something good at this price point. If only there were better inputs...
What happens when you put them on some furniture the way normal people do? It's hard to believe that isn't factored into how they were designed.The speaker is also well controlled within its vertical listening window, though it is better below the tweeter axis than above it. I feel this should be the other way around, as this is the type of speaker you are more likely to hear while standing up. ± 0/5/15 vertical:
Yeah so locked in whilst able to send tidal, quboz, Deezer, Amazon etc to themThese are probably sold far below cost, like a lot of Google or Amazon hardware. This is not primarily a speaker, but an enabler machine to lock the user into the Google ecosystem, where the profits are generated.
View attachment 86318Still cool, to see.
Sorry but I was looking at the google nest audio faq and no where does it say Stereo. If multiple units of this just plays in group then doesn't this just mean Dual Mono instead of real Stereo?
I see 2 ways of connecting to PC:
- Bluetooth (requires bluetooth dongle on desktop, or built-in to all laptops/tablets)
- Cast music from PC to speaker, using Google Chrome browser (or other chromecast compatible players like Spotify Connect [premium feature]). (PC must on same subnet as speakers)
DSP, and a well chosen driver.How do they get such good low end extension in a sealed enclosure with a 3 inch woofer? Even with a Linkwitz Transform, that seems wild.
Very nice review. Impressive performance.
Anyone seen measurements for the Google home max, I tried searching for some but found only it's physical dimensions and links to this review.
If it wasn't made in similar way to this I wonder if the next version will be, seems potential for something pretty impressive in a Google nest audio max.
Can anyone find any info on the external power supply, the physical size specifically?
If I can mount a recessed outlet up on the wall, put the power supply in there and mount the speaker in front of it this could be a great option for the dining room audio.
Dimensions for the power supply chunky bit, sans the prongs, are roughly 2 3/8 x 1 3/4 x 1 inches.
