Geshelli JNOG2 Review (Balanced DAC)
Rate this DAC:
    Votes: 15 6.1%
    Votes: 75 30.7%
    Votes: 114 46.7%
    Votes: 40 16.4%
Test Burson V7V against Burson V7C against Sparkos 3602 against Sparkos SS2590 and tell me (honestly) that you don't hear a different tone and soundstage. I have the J2S with the 4499 chip. I have cycled all 4 of the op amps above through my J2S. I used each for a minimum of 2 weeks before changing to another.
I very much liked the Burson V7V and certainly preferred the Burson V7V over the Sparkos 3602 that came installed. I didn't care for the V7C. However, the SS2590 took this DAC to another level. The dynamics, attack, separation, and soundstage all improved from acceptable or good to excellent. For hard rock and metal (my preference) the SS2590 was easily the best sounding.
I think the ability to easily change op amps puts The Geshelli Labs above comparable SMSL and Topping offerings. I donated my SMSL to a family member after I heard this J2S with The SS2590. The J2S with 4499 chip and SS2590 op amp continues to impress me every time I listen to it.
I take it you have heard about bias?
Inherent bias cannot explain for example, why I am able differentiate Ti OPA1656, Burson V7V, and Sparkos SS2590 on the output stage of a Geshelli J2S DAC in a matter of seconds with a familiar system and material in a blind test. I wish I could attribute this to a special extrasensory perception that I could eventually harness to win the lottery, but others keep reporting strikingly similar observations for the same respective devices. Either we are all sharing the exact same hallucination or these differences are both real and consistent.
My assessment is like different vacuum tubes, different op amp designs in sensitive audio circuit positions can influence sound in ways that are audible and interesting. The good news is anyone in doubt (like I once was) is free to perform their own testing and reach their own conclusions.
i can too fwiw. ss2590 ftw
i made that j2 sparkos happen. By that I mean I had the first prototype made and still own it. I then hooked up Sparkos with Geshelli and the rest is history. So really I didn't do that much other than spent a bunch of money and then hype it. Oh and I talked with both companies at length and worked out some details. I also begged Sparkos to make adapters for the SS2590 for a dip 8 socket years ago. Then bought the first ones they made. It's been a total pleasure working with both companies for real.
I also have a modified A3 Pro which is run entirely by sparkos. Single ended amp. I removed the protection caps from the circut so the analog out is completely naked running from the sparkos and therefor a bit dangerous in case things go wrong. Only way to fly.
As much as your personal anecdotes and opinions go, this is still audio science and not head-fi, these last pages is much less "science" and much more "I hear what I hear",
which (IMO) is not the place, really.
op-amp rolling has in fact been tested, what matters most is the circuit and without some electrical engineering knowledge as well as design knowledge, you are really just rolling dice. The original design is usually optimized for cost/efficiency, maybe you can get some marginal beter performance placing a more costly and better performing op-amp, but without some back and forth and validation, who knows? You're really just shooting in the dark. Besides, most of this burson, sparkos etc stuff is really just convincing you of "discrete" is better. For some reason, "just use your ears".
Again. Not very scientific. More like hocus pocus. End of rant, enjoy your gear; just think about it.
In post #8 of the discrete op amp discussion you provided, Amir plainly states, "We are actually (about subjective impressions). It is just that the subjective testing needs to be controlled and be within the cycle of our short-term memory."
For anyone curious as to if the differences between various op amps are audible in, for example, the input buffer of an audio amplifier, using the same system, same content, same everything except the op amp, with all test clips being accessible within the cycle of one's short term memory, here is just one such test posted to YouTube: 10 Op Amps Tested . In this format, the viewer can toggle back and forth between different op amps and reach their own conclusions. Obviously, this is best observed through a good audio system. To get around the YT audio compression, provided in the text is a direct download link to a 6 GB higher resolution version of the same video for those so inclined.
A little bit off-topic
When a DAC does not have a 12v trigger input, in a case like with the Geshelli, can I leave it on all the time and only connect my streamer's trigger to the amp's trigger?
You should be able to leave it on all the time
Uh huh.
Hello
I'm new here, I dont understand, have you heared it in comparison in your system?
edit: If yes, in what way is the e70 sounds better to you? soundstage? depth? clarity?
They are both good DAC's. For it's price the J2 with the AKM chip is a very good DAC. Only trust your own ears not only the measurments are important.
Can I use a Mean Well switching power supply 12v 5a in the J2 akm4499?
Yes but why use a switching PSU, it already comes with a decent one.
Thanks...I read in youtube that the Gst60a12-p1j is superior to the ifi powerx. And by looking at the internal picture have lots of part
Try this one https://www.fiio.com/pl50
Meanwell: 120mV ripple
Fiio: 20mv
