Luxsin X9 Smart Stereo DAC & Preamp
Rate this smart DAC, HP Amp and Preamp:
    Votes: 4 1.3%
    Votes: 19 6.4%
    Votes: 102 34.1%
    Votes: 174 58.2%
Jitter increases with the EQ enabled as shown in the review.
Its usually more than that we have a tread I can’t find where someone testes the mini DSP and a number of artifacts shows up depending on the eq and crossover settings.
You expect to loose snr/sinad proportional,to the headroom and peak boost you choose to have but that’s where it should end . Ie the noise floor is where it is .
A really nice box with some great features. Its interesting with these "Smart" DACs. There are about 10 features that could be implemented for a full digital pre-amp use case. Some examples....
1. DAC
2. All digital audio inputs...Coax, Optical, USB
3. ARC input
4. Analog inputs with high quality ADC
5. Phono input MM/MC
6. Trigger support
7. Sub support (1 good, 2 best) with high pass support on the analog outs (why is it that smart DAC producers can't wrap their heads around the fact that a large percentage of people want to use these boxes with 2.1 or 2.2 system?)
8. LAN/Wireless Network connectivity (for streamer support)
9. Parametric Equal with configs for all individual outputs
10. Any number of other DSP functions from streaming and/or protocol support to zone/grouping configs
In the old days, you bought a pre-amp that supported about 20 functions and you only used 50% of them. Now, all of these new Smart DACs implement a limited number of capabilities/inputs/outputs and you are left figuring out if the box you're looking at implements the ones that you need/want. For me, this has everything that I need except a USB digital out....so close.
Why do you need USB output? What device is it for? What are the benefits of this?
I'm very interested in buying one of these units but have a couple of questions/comments before dropping the cash:
- what's the estimated support lifecycle of the product e.g. will there be functional and/or security related firmware updates for x years?
- what's the warranty period on these?
- which Wi-Fi standards are supported? e.g. WPA2 and WPA3
- has the web UI been security audited?
- can Wi-Fi be disabled via software?
- it would be useful to have the firmware changelog available on the download page instead of just in the forum.
Cheers
Cheers
Reply inline.
[Luxsin]: We are not a company that appeared overnight. Luxsin is a newly established brand under the same group as Eversolo. Our parent group (Zidoo) has over 10 years of experience in the audio-visual industry.
[Luxsin]: One year warranty
[Luxsin]: Support WPA2, WPA3,Wifi5.
[Luxsin]: I assume you are concerning about the safety, agree with Amir's suggestion to put it behind a firewall. other than web UI, X9 also support APP control
[Luxsin] : the Wifi can not be disabled via software for now. without wifi, users won’t be able to add new headphone models to the X9 or use OTA updates, APP control/web UI also not supported.
However, we have previously tested a special firmware version with Wi-Fi disabled, and it worked without issues.
[Luxsin] : Latest official firmware always been upload in below link for user to download.
Regards
Luxsin
Im actually disappointded by the amp section. Considerably less power and more noisy than my humble A50iii.
Reply inline.
Regards
Luxsin
Thanks @Luxsin - I appreciate your response and engagement with the community!
Which EQ Database is beeing used? I´m questioning if there are predefined EQ Profiles for Focal Hadenys and Dunu Arashi
Dunu Arashi just been added to our database as per request from a X9 user, Focal Hadenys is not in the database yet.
Ah, that stinks. The stereo sub out is precisely the reason why I am interested in this!
I know this post is a little old, and I don't mean to butt in, but the Eversolo DMP-A8 does have a dedicated sub out - not sure if maybe someone was referring to an older iteration, but it definitely has a sub out and dsp bass management - I have one.
Yes but it is mono, correct? Not full stereo.
I voted fine instead of great because the headphone amp is rather mid for today standards.
Why no DSD input support for HDMI?
The HDMI input is ARC, not I2S/IIS. You’re thinking about I2S/IIS over HDMI, which would support native DSD. ARC over HDMI can either carry linear PCM or Bitstream Dolby/DTS.
No, what im thinking about is front ending a dac with a Sony UBP-X800M2 "universal" disc player which only has hdmi out that ordinarily would be connected to an AVR or AVP.
I looked at the back of this thing and thought the usb connections were a lan connection. Got real hot and bothered for a second. Would love an all in one unit like this for streaming and headphone amp that I could connect to TV and speakers etc. Wiim, eversolo just don't cut it (eversolo ui also looks like an android piece of trash).
Placeholder for specs
Luxsin X9
Display4-inch TFT Fully Laminated Touchscreen (960X400)
DAC solutionAK4191EQ + AK4499EX
DSPAKM 7739
OpAmpOPA1612
HP Amp chipTPA6120A2
Processing & USB solutionXMOS (XU)316
Bluetooth solutionQCC5125 (BT5.0 with aptX / aptX-HD / SBC / AAC / LDAC support)
Wireless solutionWiFi 2.4GHz
Trigger support12V trigger in/out
USB-A inputUsed for firmware updating only
USB-B/USB-C inputWindows (10, 11), Android, IOS, support DSD512, PCM 768KHz 32-bit
Optical/Coax inputPCM 192KHz 24-bit, DoP64
HDMI ARC inputPCM 192KHz 24-bit
Analogue inputRCA (unbalanced), max gain +10dB
Analogue outputsXLR3 (balanced), RCA (unbalanced), Subwoofer
Rear XLR output4.2Vrms @ 0dBFS, 20Hz~20KHz
Dynamic range & SNR: >128dB
THD+N: Under 0.000096% (-120.3dB)
RCA output2.1Vrms @ 0dBFS, 20Hz~20KHz
Dynamic range & SNR: >125dB
THD+N: Under 0.00010% (-119dB)
Headphones output4-15Vrms @ 0dBFS, 20Hz~20KHz
THD+N: Under 0.00016% (-116dB)
Single ended (6.35mm):
16Ω: ≥ 2100mW (THD+N: Under 1%) @ 5.7Vrms
32Ω: ≥ 1700mW (THD+N: Under 1%) @ 7.37Vrms
300Ω: ≥ 230mW (THD+N: Under 1%) @ 8.3Vrms
Noise floor: 4.4uV
Balanced (4.4mm/XLR4):
16Ω: ≥ 2650mW + 2650mW (THD+N: Under 1%) @ 9.2Vrms
32Ω: ≥ 3000mW + 3000mW (THD+N: Under 1%) @ 9.7Vrms
300Ω: ≥ 920mW + 920mW (THD+N: Under 1%) @ 16.7Vrms
Noise floor: 5.1uV
Headphone featuresProprietary HP-EQ (Headphone Equalisation) technology,database
Automatic headphone impedance detection for the 6.35mm and 4.4mm ports
Power supplyInternal Ultra-Low Noise Linear Power Supply
Weight3.72kg
DimensionsWidth: 300mm / Length: 206mm / Height: 65mm
Once you get into Headphones and use PEQ there is no going back. I ordered it. The question is how good is the PEQ implementation? Presently I am using MIniDSP SHD Studio to do PEQ. It executes PEQ using 32bit 96khz. However, I have to send the signal via AES/EBU to my Topping D90 3. Then Topping D90 3 sends balanced to Gustard H26.
I tried using the PEQ in the Topping D90 3 but the software is crazy buggy and the implementation is poor. What I have learned from this is that you cannot simply judge the components separately but as whole. In other words, would the integrated Luxsin X9 used alone with its internal PEQ outperform the 3 units I use to accomplish this same task?
I will know within a week. PS: This unit does not seem to work well with Toslink input. However, USB HDMI and Coaxial may be really good. The 50MILL test above may not represent the real performance as there are 3 power levels that need to be chosen based on the headphone's impedance (or can be used with AUTO setting).
Given that adjustment I am confident that the noise floor at low output will perform better.
This is a review and detailed measurements of the Luxsin X9 stereo "smart" balanced DAC, preamplifier and headphone amp. It was sent to me by the company and costs US $1099.
Luxsin is a new brand for the Zidoo/Eversolo company and focused on higher-end audio products. In this instance, we have a gorgeous 1080p touchscreen display that lets us navigate through rich set of features and visualizations including that nice VU meter. Further, due to inclusion of Wifi, you can control the unit using an app or with web interface.
Balanced headphone output is provided including the ability to automatically enable filters to adapt your headphone to that of Harman curve. Failing that, you can program your PEQ. Alas, I started with an older version of the firmware where these features didn't seem functional.
I am starting to call DACs with such value added features, "smart."
Back panel shows other cool features such as HDMI and analog inputs:
For those of us who only have one analog source, this is ideal and eliminates the need for a premplifier.
Nice to see trigger input and output to automate power sequencing of downstream amplifiers. Subwoofer output is provided including ability to set its gain/filtering. If you combine this with PEQ for the main channels, you have your ideal integration of sub (although you still have to know what you are doing).
Luxsin X9 DAC Measurements
The pedigree of Eversolo is apparent the moment you see superb dashboard results:
This lands the X9 near top of our ratings:
Sorry, forgot to capture a zoomed result.
RCA results are not that far off:
HDMI results are essentially the same as USB:
Dynamic results indicate a completely quiet system even if you rob some from it for EQ headroom:
Linearity is perfect:
IMD distortion is kept very low:
As is loaded output at 600 ohm:
I only tested the default filter which performed as it should:
Wideband response is excellent as well:
The only tiny failing was in Jitter test when DSP is active:
Luxsin X9 Headphone Amplifier Measurements
Lots of power is available into low and high impedances:
After testing, I noticed a menu item related to automatic gain. Apparently the unit measures the impedance of the headphone and adjusts the gain appropriately. I did not try to test this.
Without explicit negative gain, we don't get the lowest noise at 50 mv output:
Luxsin X9 Preamplifier Measurements
Dashboard results are the type of performance we typically see: good enough for our analog sources but not reference quality:
The X9 sports a beautiful and functional display and menu system. Inclusion of Wifi means you can program and interact with the unit easier using the App or the web interface. Programmable EQ system lets you adjust the headphone response (or speaker) at hardware level, making it functional with any source system/app. Analog input and inclusion of HDMI means you can fully integrate all modern and vintage devices into it.
The price is up there and initial software bugs I found, unexpected. Compared to typical high-end DACs though, the X9 is much cheaper and far more functional.
I am going to recommend the Luxsin X9.
Great review as always. I wonder if you reduced the gain to the lowest setting when doing the low output 50mill test? There are 3 settings. Your results for that test seem like you may have used the medium output setting. If so, the results should be much better at the lowest gain setting.
Poor from which standpoint: is the UI poorly implemented or the actual PEQ filters (Freq., gain, Q-factor) incorrect?
Again, “outperform” what?
