I am especially looking forward to more Audio-over-IP (and PoE-powered) speakers.
None of these newly announced monitors support audio over IP (unfortunately).
Nice new releases. I agree that Audio over IP should be included in their new releases, especially since they have had the 8340 IP monitor already for a while now with AoIP support.
Hi,
just for my curiosity, what's your use case for AoIP endpoint directly in such monitors/speakers and why you're disappointed by that?
I've done some projects with AoIP.. and I see some unquestionable benefits for routing lot of channels at longer distances (in context of bigger buildings, live, broadcast), inherent ability to mult signal to several destinations etc.
But quite honestly, I don't so much of its appeal for direct connection of studio monitors, not to mention some "fancy" home HiFi setup. Lot of times, when I speak to people, it seems to me, they think AoIP, VoIP like some kind of universal solution of future (hey it's at front page of every pro-magazine for almost decade).. and they want to have everything buzzword compliant regardless of particular use case or common technical sense (actual problem leading to solution, not the other way around
) and thinking about networked audio also among devices, which are all placed on common desk in 3x4m room
To me, as I've mentioned, forte of AoIP is in larger setups, where you typically need to pass many channels of audio to various destinations, employ some failover.. broadcast, live, OB trucks. In most cases, there I would route many signals between workplaces/rooms. Almost always there is in use some other network "endpoint" device, be it mixing console, monitoring controller, which is in close distance to actual speakers with conventional inputs. If I need just kind of "remote" monitoring speaker, there is no problem to add such small, PoE powered monitoring unit (solves also need for HP amp) say with Dante. Even in the case of AES endpoint, if it will be really necessary, there are plenty of products out there.. compact and likely cheaper than some special expansion module like offered by some monitor manufacturer.
It's true, that 8040 has already IP endpoint.. I see that, that's IMO right monitor in their lineup for broadcast setups.. compared to larger midfield and fullrange systems, which are mentioned in this announcement and where I don't see much practical advantages.. it's aimed to studio rooms, where inputs are handled by separate controller or fed directly from some larger audio interface.
And btw. at 8040 its input is implemented separately from GLM net, so you still need to connect three connections there (mains power, GLM and input). So even simplified cabling isn't actual benefit.
So that's why I'm curious, what's your intention with that.. or maybe you have different practical experience with AoIP.
Michal
