Genelec 8030C Studio Monitor Review
wsmith
Yes, he definitely should test them both ways. The room reflections will be quite different between the orientations.
For those unaware, the models being discussed are near-field monitors. Designed to be used close enough that their sound pressure overpowers accoustical reflections which are thus rendered moot, if you will.
As for for stand-mounting, using anything but the Genelec mounting plate will transmit vibration to the stand and also potentially back to the speaker. The Genelec plate is designed to work with the isopods.
Would that make a difference in satisfactory operation? Your mileage regarding vibrational resonances may vary. One could get out the accelerometers for testing... I'll just stick to the mounting plates.
wsmith
The mounting plates can only be used with the monitors in an upright position in order to interface with the isopods. The table stands look cool though.
LTig
Europe
The K&M mic stands I use are at least as good in isolation, probably better. Remember these are designed for microphones and must prevent movements of the desktop reaching the microphone.
stunta
Boston, MA
Given that, I am surprised they can hold loudspeakers steadily despite their weight and larger volume.
wsmith
I would argue that:
1) vibrational resonances are nearly the potential problem with mic stands compared with speaker stands.
2) stability of K&M and other comparable, quality stands, really isn't in question. A mic stand can certainly be modified with an adapter to hold a speaker and be stable.
3 The question is how does it isolate against transfer of vibration? The plate catalog no. I refer to in this thread accomplished that function. Other mounting designs may be stable but don't properly work in conjunction with the isopods.
Again, your mileage may vary on whether vibrational resonance is a concern for your particular usage. Genelec makes other types of mounts such as back plates, wall mounts, ceiling mounts, etc. Obviously users of those systems dont find them to be detrimental. As long as the monitor is at ear level and doesn't come crashing down to the ground is enough for them.
wsmith
As a recording engineer of live events I admit that isolation, i.e. shock mounting, for example, of a mic is often important. But I've see any of those that could be adapter for use with a studio monitor.
Killingbeans
Bjerringbro, Denmark.
The base of the K&M stands has a thick rubber ring on the bottom. I don't know if it isolates as well as the isopods, but it shouldn't be far off?
wsmith
The Genelec plate is specifically designed to isolate the monitor from the stand by preserving the functionality of the isopod which de-couples the monitor from whatever it sits on or whatever the plate is screwed down on.
Look at bottom of isopod to see holes which mate to prongs on plate. That mating prevents monitor from tipping over yet it doesn't interfere with isopod functionality.
A rubber bottom of a mic stand limits transfer of vibration of a stage from entering mics, especially ones with self noise. Performers often like to tilt a mic stand and sometimes the base will "wheel" around a bit too. Then they'll let it plop down flat as they let go of the stand. Handling, or self-noise noise can also be further limited with a de-coupling rubber shock mount to attach the mic to the stand.
Typically, needing to isolate stage rumbling or a mic's handling noise with a rubber stand base isn't needed in a DAW post production monitoring environment. But isolating the monitor is.
LTig
Europe
It could be better. The rubber of this ring is much softer than the isopods, so the resonance frequency must be quite a bit lower.
LTig
Europe
Well, there must have been a reason why my Genelec 8020a has a microphone stand compatible screw hole. Why not use it?
wsmith
By all means then. I am just offering the alternative position that decoupling the speaker from any chosen stand by using the iso-mounting plate + isopod would logically be better. Having said that, if you dont have any resonances feeding back to the monitor's housing, then you need not concern yourself with decoupling.
EchoChamber
My 8030C’s were delivered today!! I’m really impressed by the level of detail I’m getting out of them. Imaging is also excellent. I’m impressed... Although their intended application is in my home office system, I’m trying them in my main system while waiting for the 8351B’s...
stunta
Boston, MA
q3cpma
France
EchoChamber
Just curious as to what the delivery times are. I understood at one point it was hard to get the 8351b's.
I ordered mine in mid August. Yesterday FedEx told me they are on the way...
Maiky76
French, living in China
EchoChamber
scherbakov_al
Санкт-петербург
Good overview. The good news is that more attention is paid to nonlinear distortion. Smooth frequency response, that's cool, of course. But you twist your head, your auricles create frequency changes, the location in the room changes... I think that from a certain level of unevenness the frequency response ceases to be significant, because over time, hearing adapts slightly, as it adapts to the color temperature. But if nonlinear distortion are present - there is no getting around - they can be heard or can make the sound cloudy. Although sometimes they can give a feeling of "assertiveness". For example, I can clearly hear the 3rd harmonic from 1000Hz, which is 50dB below the main signal. Especially, if in the room 1000Hz forms a standing wave, then moving in space you can get into the zone where 1000Hz will fall in level, and 3000Hz will be clearly audible.
Curiously, DACs and amplifiers have reached stunning levels in nonlinear distortion .. distortion is sometimes below 130dB! They are transparent to sound. But the speaker has a distortion level of -50-60dB. I would ask researchers to pay more attention to the topic of measuring nonlinear distortion in speakers. It is interesting! And also add measurements to the table, where it would be possible to compare different dynamics with each other in terms of nonlinear distortion. Thanks!
