Fostex PM.03 Active Speaker Review
I've had the PM0.5D with the mini sub for nearly 2 years now got it on clearance sale for around $330 AUD, It is used as computer speakers about 50cm away, I had to EQ it harman+2khz+4khz lowered due to design/flaw, and some preference for a tiny bit lower mids tiny bit lower 4khz and it sounds perfect for me so its definitely EQable just takes a while.. (tweeter at 1-2cm lower ear height, triangle slightly facing outwards, hollow 140cmx70cm desk + 1cm 2 layer blu taked together cardboard under the speakers, the desk in particular affects the sound in a positive way, maybe its because of the metal hollow loop legs, due to the energy going through it or rather the hollow wood design of 5cm thick with 3-4cm hollow lines verticularly whatever that is called, ive hard wooden full desks before and that makes any speaker sound bad, muddy and full of mids that destroy the sound for me)
Any pre/ post eq FR can we see?
I'm too poor and don't have access to any gear to do measurements, all by ear, think of it sounding like a ath-m50 (not x) or swan m10's.
ic, too bad then we are not sure what actually changed in the FR results in, the fostex are great performer at a really tight budget IMO.
Yea they sound better(I'm not an audiophile) like fuller mids and you can barely hear that rubbery sound cause the woofer is made out of it and kevlar, compared to like dry metal cheaper speakers, if that makes sense. the 2khz crossover boost is because its a passive cross and droops there?, 4khz i dont understand but its ear bleeding and needs to be lowered that far.
I looked at harman curve 2015 values which are below, they are slightly higher mids than mine, the harman sound worse to me.
Harman curve from flat
125; -3.4db
250; -5.6db
500db; -4.4db
1k; -3db
2k; +2db
(3k; +7db)
4k; +5.4db
8k; -0.8db
16k; ?
Wow that's an incredible price you got the PM0.5 for! I'm in Aus as well and just ordered the PM0.4 at half price, will report in on the sound when they arrive.
Current sale is here if anyone also wants to join the Fostex PM club:
@Stoogie how much benefit did you get from adding the mini sub? Not sure adding a sub which costs more than the speakers themselves would be worthwhile given the minimalist form factor of these speakers?
Hi everyone,
When using these speakers I have a big bump at 150Hz. Here is a quick and dirty measurement, just one position but I believe communicates my problem well enough (so ignore above 500Hz):
I'm new to speakers so I do not know what's going on here or what I need to do to fix it. I'm guessing the big dip after the 150Hz peak is related somehow and that it's something to do with my room or where I've put the speakers?
Thanks!
Hi everyone,
Thanks!
150hz is quite common for desk reflection, you could try find something to lift your PM0.3 to ear level at tweeter height and it should be a lot better
Hi everyone,
Thanks!
I have them on my desk as long as I can remember,never bothered to measure them as they are not speakers for critical listening,just for convenience.
But if this peak is present on mine too I would consider it a guilty pleasure :p
Fun aside,is a normal desk untreated response,just EQ it and let them be.
Thank you, I do have them elevated but on their own wall shelves above my desk so this would fit your explanation.
Try pull it out a bit and minimise the front shelf “floor” in front of the speaker and it should improve
desk stands might be a good option?
I've seen some that clamp to a desk and you can move the angle around - great for studio monitors
Another VERY Happy PM0.4 owner here :) (Unbelievably I got the pair for $50.00Aus)
Initially running them Direct from PC via a JBL Nano Patch (Volume Control) and whilst they were great, my recent purchase of the S.M.S.L. C200 DAC, has 'Transformed' them !! :)
I too would Love to get the Mini SUB2 but is beyond my budget atm :(
Just after I found and purchased the PM0.4's I found a PM0.5 system, (with the correct Sub), for only slightly More than the price of the Sub !!
Do you mean PM0.3? That is the model reviewed here, PM0.4 is bigger.
I find the mini sub2 essential with the PM0.3 as the bass rolls off so fast below 200Hz. You could get that PM0.5 + sub set and sell the PM0.5s to keep the sub, or ask to purchase the sub separately?
No someone else mentioned the PM0.4 earlier and I was just adding my approval of them :)
I was thinking the same thing, but if I did, I'd probably keep the Whole PM0.5 System and sell the PM0.4's :)
Hello community,
I have owned a pair of these for over 10 years, they have travelled with me on planes in checked suitcase, been used in various living rooms and if you respect their phyiscal limitaitons, there is nothing but positive to say about them. No they won't shake your walls or hurt your stomach with insnae bass, but they are miles ahead of any plastic junk computer speakers or even cheap mini all in one systems. I have played lossy and lossless music on them at reasonable, apparment volume and still use them in my bedroom. Two friends had the bigger PM0.5 and we had appartment parties on these, no problem. One is a pro recording engineer also owning Neumann, Dynaudio's, Avantone etc. and always said the PM0.5 (I can't remember which exact version) were a lovely bargain for their price.
I picked up the old pm0.4 recently, it has decent little drivers in it. Sounds fine though slightly bright and messy in upper mid area. Might be the room they were in too. Could be good for monitoring purposes to make sure you create a clean, less harsh mix, though you'd need something else for bass of course. Would be interesting to see if they measure with similarity to the pm0.3 in this review.
Whilst I can agree about the 'Brightness' perhaps (Better to be able to reduce it, than Not having enough), I'm not sure I can agree about it also being 'Messy'. I have heard FAR Worse !! including in some studios and sounds (to My ears), so much better than the ubiquitous Yamaha NS-10's .......:)
I also recently managed to find someone selling a PM0.5-Sub, in very good condition at a really great price :) ..... The 'Combo', sounds GREAT !!!
