Fosi Audio V3 Mono Amplifier Review
Rate this amplifier:
    Votes: 13 1.8%
    Votes: 23 3.2%
    Votes: 139 19.4%
    Votes: 540 75.5%
We still don't know. because @Fosi Audio IS CONSISTENTLY FAILING TO PROVIDE CLEAR INFORMATION. (Sorry for shouting, but this is getting ridiculous now.
I simply don't understand why.
My recommendation to anyone thinking about purchasing to hold off until this is rectified.
Just like a kick starter in the balls.
Just being clear I'm using one 48v 5amp from v3 and the other sent with my kit 48v 10Amp brick.
Maybe if they used Delivery Dates it would help, as I pre ordered mine in early July and got it delivered 14th Aug.
It begs the questions
Testing is done on single test frequency feeds, not speakers right so polarity doesn't matter?
I love the single fact the tests were done on a single unit with one unit from a product that should be tested in pairs off one PSU? This might have highlighted the dual psu problems?
Don't get me wrong I love the monos just testing from Fosi and independent testers could have corrected stuff earlier because that DC filter didn't work for me, it hummed if one unit was off and popped everytime it was on or off.
Sorry if I missed it, but what do you do for a sub out when the channels are separated to two boxes like this and I only use one active subwoofer?
Ignore this. I was thinking these had a sub out.
Hi there, let me explain it.
For V3 MONO units purchased on or after August 2nd, 2024: The output polarity of V3 MONO has been revised. You can connect your speaker terminals normally without reversing the polarity.
-For V3 MONO units purchased before August 2nd, 2024: Using two V3 Monos together won't cause any phase issues. However, if you integrate one V3 Mono with other equipment, please note that the phase might be inverted(both RCA and XLR). To achieve optimal sound quality, please connect the speaker terminals reversely when connecting to your V3 MONO amplifier.
* If you purchase the V3 Mono from the Fosi Audio website after August 2nd, 2024, it will be the updated version. For purchases from platforms like Amazon, eBay, or AliExpress, please contact our customer service to confirm which version you are receiving.
We apologize for any inconvenience caused by this and appreciate your patience as we work diligently to rectify the problem.
But how to differentiate between both versions if they haven't been bought directly from Fosi Audio in China ?
I checked with mine (several) V3 Mono units bought through German Ebay/Fosi Audio and delivered from a German warehouse a few days ago and none seems to carry a serial-number or production-date sticker.
The only way to know if they have the speakers phase reversed on the RCA input (or both: XLR and RCA inpust ?) would be to measure them individually !
They all carry the same production-ID - at least on my units - on a bottom sticker...
Looks like we need to compare before and after pics by ourselves. Le sigh
Hi
Thanks for the reply - perhaps you can expand a little
Prior to the fix:
You say "might" be inverted. Is it? or Is it not? There is no "might" - unless you have shipped different designs at different times.
Is it definitely BOTH the RCA input and the XLR input that are inverted? Because some here have done some tests that indicated only one of them is inverted.
AFTER the fix - are both inputs the same and non - inverted?
HOW have you implemented the fix? Assuming both inputs were inverted presumably it was only necessary to swap the wires to the speaker terminals internally? (Knowing this might enable people to check if they have a fixed unit or not)
Thanks.
The problem is, that for the 1st delivery the German "Widerufsfrist" has been depleted by the delivery of the "gift" (July 26), because ebay Germany had been signaled the delivery of the amps, although the "real" delivery of the V3 Mono units happened quite a bit later on; their delivery has been around August 8th. The second delivery happened lateron, where "gift" and amp delivery happened on consecutive days. Here I am still in the German "Widerrufsperiode" of 14 days, ebay stated even October 13th for the return. What a mess...
The statement of Fosi Audio concerning the polarity of the V3 Mono speaker ouputs confuses me too, because now the signal to the speakers of both, XLR and RCA input, are inverted (?), although, following by the comments of several buyers who seem to have tested it, this should have happened only be for the RCA inputs... Strange !
What is the real situation now ???
Note: That "official" statement I am referring to has not been sent to me, but seems to have been published on the Fosi Audio web site, but where ??? I can't find it...
Here is a photo from the Fosi FB group that shows new vs old.
They just reversed the output wires to the speaker terminals. :facepalm:
@Fosi Audio ,a simple question:
Does XLR and RCA input result in the same polarity at the output?
Have you tested that?
Because some reports said otherwise,that they are different.That's the important test.
Maybe the evidence of RCA and XRL having opposite phases are weaker than it seems?
I have been following this thread and I only remember one report of different polarity of RCA vs XRL, and that was based on a room measurement with sub integration iirc.
On the other side, there was another member that made more in depth measurements showing RCA and XRL had the same phase. To the best of my knowledge Fosi never said the phase of both inputs was different.
My apologies if I have missed something.
PS: I have the feeling that Fosi should have done nothing but perhaps adding a caution sticker, now there are amps out there with opposite polarity, and being monoblocks…. Just my opinion
That's my feeling too.
But as long as this report exists (even if it was a user-error) it's dead easy to make the situation crystal clear once and for all.
Yes. Fosi is at sleep
Well my very detailed support ticket regarding if BOTH RCA and XLR inputs result in the same speaker polarity, was answered with "You can order them from our official website, it's the new version with the good polarity or phase." :facepalm:
And in the meantime waiting for this stellar answer the 20% off code expired. I think I am just going with Hypex at this point, no phase issues or hotter than spec heat or DOA's or blown units for a still affordable solution.
That's a bit harsh - they have already responded multiple times on this.
OK, some of us aren't 100% sure that they understand and have fixed the RCA/XLR inconsistency (if it ever really existed) but Fosi do say it has been done. Is there evidence that there actually is a phase difference?
That “might” line is accurate; it was specifically in reference to using the V3M with other equipment— e.g. powered subwoofer, or another amp driving satellite speakers — which might or might not be in phase with the V3M. (Technically true for any amp I suppose, but presumably more likely with ones like the V3M that invert phase.)
See the response above. I asked them through email if the fixed units I will get are fixed on both RCA and XLR only to not receive any response at all.
There will be tons of extra confusion when these hit the aftermarket, very few will know if the unit is fixed or not, because they do not even mark the units with a serial# or even a sticker of some sort to point out that this is version 1.1 or whatever.
There are people who are doing, “instrumented,” testing using Audessy (SIC?) and finding that the XLR was correct and the RCA was wrong in original units, and now RCA is right and XLR is wrong on updated units.
-Ed
-Ed
And this is the sort of information Fosi should pass on to the consumers. And which versions are affected.
A new revision should get it all correct.
