- Joined
- Feb 16, 2021
- Messages
- 8
- Likes
- 1
Folks, this is my first post on the forum - I've been lurking for awhile and I'm really grateful for everything I learned here over the last couple of months.
I'm sharing first impressions from the Audiophonics HPA-T400ET 3 Way Purifi amplifier.
Unfortunately, the unit I received was defective (faulty power relay), which prompted me to return it.
I took the opportunity to return it as I incidentally found that Apollon Audio is releasing a new 3 channel Purifi amp with adjustable gain that goes to 29dB that's a much better match to my Denon x3600.
I also found Apollon's support more personal and engaged, and along with the perceived higher quality custom build helped justify the higher price.
All things considered, I'm reasonably content with my Audiophonics experience, and I will consider their products in the future. Being in Europe I find that they offer the best prices for Class D builds on the market.
I'm leaving my original post and impressions for posterity:
I got this amplifier to power my L/R Kef R5s and center L2C speakers. It's paired to a Denon X3600H receiver. Depending on how things go, I might trade my current receiver with one that supports disabling the internal amps (e.g. 3700, 4700 or this year's models) for a clean 2V output on all channels.
Order experience:
Issues, Troubleshooting & Return:
[Update 4/21/21]: The Audiophonics support confirmed that the behavior described below is not normal.
[Update 5/06/21]
Layout photos:
I opened the amplifier to check the gain settings on the amps, and took the opportunity to make a few photos of the layout.
Order experience:
- Ordering was a breeze, the Audiophonics support was responsive and answered all of my questions in a timely manner.
- The amplifier arrived within a few days from France. I'm based in the Netherlands.
- Packaging was good, with a generous amount of padding and protection.
- The industrial design is okay, it has a clean, if generic look. No massive stickers/logos which I appreciate. The fins on the chassis are quite sharp and uncomfortable to hold. It's not a deal breaker, but makes handling it unpleasant. (photos below)
- The finish is matte black and doesn't attract fingerprints.
- There's no manual in the box or online, which I didn't expect and I find as an oversight. The only feature that strictly requires a manual is the gain adjustment, which is documented in a blog post.
- Initial installation was simple, as expected. Nothing of note or concern. The trigger works.
- The power button and trigger are all connected to the same controller. As others have observed with other Audiophonics models the trigger overrides the power switch.
- Unfortunately, and unsurprisingly there is a hum when the RCA->XLR cable is connected to the amplifier. I was already prepared for this risk, the main suspect being the XLR->RCA cable.
- [Audiophonics support confirmed that's not expected behavior] There's no hard power switch / way to turn off the amplifier without unplugging. My unit draws 33 watts when it's plugged in. There's no tangible difference in the power draw in stand by (LED off) and ON (LED on). Given the high power consumption and 0 difference between on/off, I'm uncertain of what the stand by state actually does.
- This is where it gets fun. A full day into owning the amp, I've still yet to get it to work. I've contacted support a few hours ago, and I'm waiting for a response. Communication is only through email/website service form, so some latency is expected.
- After connecting the amplifier to the receiver, I discovered the gain/output was incredibly low. The speakers barely produced any sound (audible only if I put my ear to them).
- Next step was checking the gain level adjustment of the amps. Happily, they were already configured to 25dB gain, as I requested with my order.
- After playing around for an hour last night, I discovered that the speakers continue to produce (the barely audible) sound even when the amplifier is in standby. I find this strange and continue to wonder what the stand by mode actually does.
[Update 5/06/21]
- Audiophonics confirmed that the power relay is faulty.
- There was no resolution for the gain issue. General Audiophonics advise was to use 20dB/4v gain, despite the amp offering 25 dB gain.
Given the positive feedback on using the 25dB gain option (see @TomekNet 's comment below), I'm still confused about this advice and assume it was a glitch in their otherwise good support. - Ultimately, I decided to return the unit, and go for an Apollon amp that has adjustable gain to 20/25/29 dB, matching well with the Denon pre-outs.
Layout photos:
