- Joined
- Oct 25, 2019
- Messages
- 11,112
- Likes
- 14,776
what do you want from headphone measurements? What do you go in looking fo
I suspected that there might be contention on putting electrical Z in the "not audibly significant" section - my reasoning, at the risk of being controversial, largely boils down to a position that for amplifier-headphone impedance interactions to significantly impact frequency response, a minimum of one of the amplifier designer and headphone designer must have made a terrible mistake...
Ah, just found this thread, and it's a useful one, I'll put across what I'm interested in from these headphone measurements. To me the proof of the pudding is in the eating, or in this case listening to the resultant EQ's that myself or someone else has created from the measurements......also to experiment with different Target Frequency Response Curves. For example theoretically calculated Target Curves like the ones from the Chris Struck Method (which is Mad_Economist's spreadsheet for instance) which allows you to recreate any speaker that has been measured by Amir in "any room of your choice". I'd also like to compare different Harman Target Curves that have been developed over the years (the different versions eg 2018, 2015, etc), and I'd try Diffuse Field & other targets. I'd like to experiment with that, so I find the practical application to the end user more interesting in terms of using the measurements to optimise our own headphones.
I am also, to a lesser extent, interested in the comparison of different headphones.....trying to evaluate/link quality of said headphones from the measurements - tricky to do for various reasons.
And thirdly and perhaps more interesting to me than the previous little paragraph...."the future of headphones", eg Smyth Realizer type angles or anything that is ground breaking that is pushing headphones forward in being able to emulate speakers in a room or an "environment" within which you find yourself, so 3D imaging I guess. Or anything that you can do DIY-style to come closer to some of this.
I'm not sure how easy I'd be able to tell apart Target Curves, but I have tried Diffuse Field vs Harman Curve on my HD600 and there is a massive & obvious difference between them, so it comes down to how different the Target Curves are from each other. It would be harder to recognise the difference between the smaller changes that have been made to the Harman Curve over the years, so that would be harder to tell apart....I've not tried comparing them yet. It's easy enough to create different EQ profiles in Equaliser APO that you can flip between with a couple of quick mouse clicks....so it's easy to compare them. I'd start by choosing a preference on my HD600 (open back) which is my favourite headphone, then I'd see if my preference still stuck when using my NAD HP50 (closed back). Yeah, and I've got my own set of "reference tracks" that I know & love from different genres of music, so I would try them out on a variety of music to guage their suitability......most of those reference tracks are tracks that I think are high quality recordings that work very well on my Harman Curve & Room EQ'd JBL 308pMkii speakers which are also set up at perfect equidistant triangle, so I try to use that as a reference to help choose the right tracks.Do you reckon if you stuck to one or 2 hp models and tried loads of different target curves (or more accurately, eq to those curves) you'd find a target you were happy to adopt?
It's easy to say you prefer eq a to stock or vice versa, I suspect harder to say prefer a to b to c
Ah I see, you mean like an output from a spreadsheet or other calculator based on the Zin of the headphone? That'd make sense - heck, if someone felt ambitious, that shouldn't be too hard for a web calculator I'd imagine.I would assume it is very easy to generate automatically from a measured impedance plot.
To be fully honest, I feel like giving me the same flair as Floyd Toole or j_j really undercredits them...B.t.w. as a side note... why doesn't it say 'technical expert' below your avatar ?
This will pose a problem, as due to the omission of lower torso articulation, head and torso simulators are incapable of bowing to anyone...Wanna badge, you pay the Watchman.
You got a purdy mouth though...Ah I see, you mean like an output from a spreadsheet or other calculator based on the Zin of the headphone? That'd make sense - heck, if someone felt ambitious, that shouldn't be too hard for a web calculator I'd imagine.
To be clear, I definitely think electrical Z should be measured, it's just a borderline pass-fail type criteria for me - there's very few cases where I see a single-digit nominal impedance and wild swings and think "this seems like a product suited to actual use". For the designs with higher but still varying impedance, it's less likely to pose a very large issue, however, which is why I was relegating it to the "technical interest" side of things. I think we generally agree thoughAll the more reason to include it then One of the great things about ASR is its measurements can reveal deficiencies and faults in devices that are not immediately obvious yet can impact performance, which in turn could influence manufacturers to improve on these deficiencies. A headphone may measure great under ideal conditions with a ~0 ohm output impedance source, but if the headphone itself has wildly varying or ridiculously low impedance (like the Campfire Andromeda), real-world usage will be audibly compromised. The fact is many multi-driver balanced-armature IEMs do have wildly varying impedance, so it would be useful to quantify the impact of this on measured headphones' frequency response for users. Similarly, many (probably the majority) of stereos and AVRs have ridiculously high headphone out impedances which will affect most headphones. If these are common problems that impact end users, then I don't think them being bad design is a good reason to ignore them, rather I would say the opposite.
Re: Zout and headphone impedance, I always liked Rinchoi's visualization of that:
Presenting both the delta and the compensated responses is IMO helpful for newer people/folks who ain't about eyeballing minutia.
What's the typical output impedance of a smartphone?
And LG G7 at 1.6 ohm.
I thought I'd drop this here to ask: what do you want from headphone measurements? What do you go in looking for?
There is old topic were guy emulate Tyll's real measurements (square plots, step response and impulse response) just by FR: head-fi topic and archived innerfidelty post. Unfortunately graphs are lost. But he emulate real measurements precisely.I like Tyll's square plots because in his graphs the headphones that were able to better reproduce those squares are mostly planars, like Audeze/Fostex/Hifiman and the bass coming out from these is different, in a better way, than dynamic cans.
Accurate square response of the diaphragm do tells me how fast and precise the bass will sound.
Designing a diaphram able to quickly rise and quickly fall is very difficult and I tend to appreciate the folks who design headphones that measure better with square signals, although I'm aware that only this kind of measurement doesn't tells much about the sound profile or audible THD.
The thing is, this characterization is at minimum misleading. The "tilt" of a square wave reflects the low frequency phase shift; this in turn reflects the effective highpass frequency. Here's a square wave looped back into a consumer sound card (reflecting its lowpass filter, thus the ringing at the edge):Thanks for sharing the link, although I can only see one pic there (I'll retry later).
I do like and I fully agree with the explain here: https://web.archive.org/web/20160411225758/http://www.headphone.com/pages/evaluating-headphones, at least this is how I see it too:
"[...] the ability for the headphones to create a straight line at the top and bottom, even if it's tilted will indicate coherent performance in the lows".
At the most charitable, they're a reasonable proxy for some frequency response relationships that have associations with what he attributed to them
