Chocomel
- Joined
- Feb 18, 2019
- Messages
- 106
- Likes
- 322
What would be the best way of measuring how fast a driver is? I'm also referring to the sounds the driver does when raising and falling too (would these be added harmonics that will reflect in the final THD?). Thank you!
Considering headphones are generally minimum phase, high frequency extension at higher output levels, basically slew rate i guess. Although I'm not sure about the limit of this behavior in Headphones in regards to the Frequency range, afaik it generally holds for the audible band.
