That is wholly incorrect from a technical perspective. A waveguide's dispersion is determined by two factors: diameter and depth. The deeper, the narrower the dispersion. The only waveguide that would have wider dispersion than a flat baffle is a swept back baffle.
Are you referring to the "line of sight" directivity principle? Or to the single-mode approximation, exemplified by the Webster Horn Equation? My "I'm not sure" stems from more recent and more accurate approaches, such as
Dr Geddes'. Please note what he writes on page 156: "
It is interesting to note that the velocity distribution in Fig.6-18 goes well beyond the 30° point on the sphere, which is in stark contrast to the established principle of “line of sight” directivity of a spherical source.".
Your subjective experience is your experience. Nobody's trying to take that away from you. But given that your technical explanation is demonstrably and obviously false, would you mind answering my question as written instead of trying to justify a subjective experience that you have had when it needs no such thing?
False based on the line of sight directivity principle? You do realize that the actual sound field is a scalar function in four-dimensional space (three spacial coordinates + frequency), formed by device with four radiating openings, one of them equipped with mesh + a semblance of phase plug (that small plate in the center of the tweeter mesh) + waveguide, and the other two having irregular form while being attached to internal waveguides of complex form?
It is not easy at all to judge such four-dimensional sound field by a two-dimensional plot. Yet, anyone who has access to KH120 and a piece of music they know by heart can easily verify what I was saying. Start listening with your ears level with the horizontal plane equidistant from the tweeter and woofer centers. Then gradually squat and observe changes in sound. For added effect, move you head left and right while squatting.
Actually, the center-to-center distance matters quite a bit. There's a reason the KH80 has verticals much like the KH310, and other monitors with 5" woofers - JBL with slot port, Focal with PR, and the like - have vertical polars substantially the same as the KH120's.
Again, look at vertical polars for other 5" speakers. The best source I know of is the Sound und Recording monitor special.
Agreed. A similarly-sized two-way monitor with a port opening under the woofer will exhibit qualitatively similar dispersion pattern. As much as I don't find this pattern attractive, such design has its uses: in my case three of the surround speakers had to be placed close to the walls, so the back firing ports or hot back plates weren't acceptable.
Unlike in some other small monitors (e.g. JBL LSR705i) there is just no evidence of midrange port contamination in the KH120's measurements.
I wouldn't call it a "contamination". Just a normal consequence of a design tradeoff. My original response was to those who found KH120 puzzlingly inaccurate while they evaluated it. My experience corroborated this, but only when I listened to KH120 monitors while they were placed too high. After placing and angling them in such a way that the lower "twirly" pattern isn't heard directly, their other advantages more than compensated for this quirk.
