Eversolo DMP-A8 Balanced Streamer/DAC Review
Rate this streamer/DAC/Preamp:
    Votes: 8 1.8%
    Votes: 12 2.7%
    Votes: 82 18.5%
    Votes: 341 77.0%
I've been reading this site for a few months and it's been very helpful to me. Thank you to everyone. I just registered to make this post to ask for some advice.
I am a past/pre digital music listener and lover and am getting back into the hobby. I am solely a 2 channel listener and I have no desire to use anything but digital music as my source and also want to listen to my music in my car and through my phone. I have a stand alone 2 channel amp and speakers and currently listen through an old receiver and a cheap CD player which I don't like but would like to build upon/replace (but mostly I listen to my stereo pair of Sonos speakers and apple music for the convenience). The DMP-A8 seemed like a perfect solution for me gain the convenience of my Sonus setup in my main system, until I read 2 reviews that said the tone control/EQ resamples hi-res down to 48khz audio. I do a lot of tone control adjusting so this is an important feature for me. I heard the points being made about not being able to hear the difference between hi-res and 48khz, for the purposes of my question I'd like to ignore that. Which is, do all hi-res streamer/preamp/dacs resample the music down to use tone control/equalizer? If so, is the only way to avoid this to go the separate preamp route? If no, does anyone have recommendation for other steamer/preamp/dacs at this level allow tone control/eq without downsampling the digitial music? Thank you.
Firstly it is a non issue, secondly there aren’t that many dacs that have built in peq, Weiss, RME, Eversolo, MiniDSPthere must be others.
Eq is also available in software Jriver and Roon for example and in some contemporary loudspeakers.
The new Quad preamp will have some some basic tone controls.
I think the 48khz may only represent the sampling rate for development of the FIR filters from REW. Those filters serve to basically develop the PEQ values to apply to the music, like sophisticated tone controls.
My thinking is that the music itself still retains its higher rates.
But then, I could be wrong on this....
Thank you for the information. The Quad is of interest and I am going to look into it further. Maybe I need to get past tone control as I embrace digital. When you say "it is a non issue", is that because it is difficult to tell the difference between hi-res and the 48khz?
Hi i want to buy soon an eversolo dmp a8 and connect it to my vintage philips fa960 via rca.
I read that the output sensitivity RCA on the eversolo is 2.6 V but the sensivity input on the philips is 150 mV.
Can i set the volume on max (0dB) on the eversolo ?
Or is it better to do the math and set the max volume on the eversolo to -24,78 dB ? And can i enter that number on the eversolo ?
I don't want to arm the amp or the speakers thanks in advance !
Hello. I am delighted with the new function, but unfortunately I am not very knowledgeable about technology. I have DMP 8, after learning about the correction from the update I ordered the microphone Microphone Umik-1 Minidsp. The instructions indicate that the program for it can be downloaded from the site, it is for Windows. I have to connect it via USB to Eversolo and run the correction function. Tell me please, how can I install the program for the microphone in Eversolo? I do not understand what it means " For best results, use a umik or other calibrated mic with its associated correction file loaded via SMB"?
Hello. Probably yes. The instructions for Eversolo say very little. Let's say I connected a microphone to Eversolo, the program for it is downloaded from the site for Windows. How do I move it to Eversolo? I don't understand it well, unfortunately.
You can use smb on your computer, or a flash drive, ......or ignore the cal file at first until you are comfortable with adding it. It makes minor tweaks.
Good morning, I have owned the DMP-A8 since March. My chain is made up of a Musical Fidelity M6S preamplifier and Hypex NC502MP power amplifier with Polk_R700 speakers and Audioquest cables. I recommend this machine for using streamers and DACs. The internal preamplifier is not up to par, for the rest it is a superb machine the sound is rich and articulate the internal DAC makes it dynamic with a deep soundstage organicity and separation of the instruments... Furthermore with the latest update it provides the calibration of the verse as in the dmp-a10. There is no machine on the market with this quality/price ratio.
In my case, with amps like yours, I retired a CJ PV5 and a BAT VK3i, I don't consider it a preamplified either, but if the power amp is enough for it, the 4 volt output...
How do you compared the A8 internal pre and MF MS6? I'm interested to know why the internal pre of A8 is not good?
In my case, despite having an internal discrete circuit, by increasing the gain in dB, I noticed sound compression and distortion from +2dB and up. Compatibility is probably better with other endings. However, I conclude by inviting everyone to choose an external preamp, in fact in the latest DMP-A10 device a linear power supply has been added to help boost the preamplification dedicated to the analogue pre and DAC section!
I believe @mirror88 said that the A8 had a sinad of -120dB, there will be no compression, it is just completely transparent.
Strange.. In first page of A8 review of preamp section , nothing was like as you are saying. Measurement wise it says perfect. I myself using A8 pre amp and find very clean. Anyway I don't have any experience with MF preamp though.
Obviously using the preamplification below +2db the machine behaves well, it depends on various factors of compatibility, energy demand of the power amplifier and speakers if they are not very sensitive. In my case I couldn't get it to express itself at its best. With the musical preamplifier the dynamics are frightening, the punch and the extension of the highs have benefited a lot. This is my personal advice... Otherwise use as you prefer
In the future it might be wise to actually look at the components measurements before you disparage its performance based on nothing more than your imagination.
