Eversolo DMP-A8 Balanced Streamer/DAC Review
Rate this streamer/DAC/Preamp:
    Votes: 8 1.7%
    Votes: 12 2.6%
    Votes: 88 19.2%
    Votes: 350 76.4%
Have a look on the Zidoo forum, I use my A-8 with Roon so not much use I am afraid.
Thanks for the tip, I have also asked on the Zidoo forum. In the meantime: where do you run Roonserver? On the DMP-A8 or somewhere else?
Just jumping in without being asked, but i believe the Roon server has to run on some kind of 'real' computer. I run mine on a Synology NAS with an SSD for the library that is always on anyway, so it's always available whenever I want to stream to whatever devices I've got scattered around.
Thanks BD
Thanks BDWoody. What is the processing power/memory on your Synology (what model do you have)?
Thanks BD
I have the DS920+.
Here is a summary of the requirements:
"Which NAS devices are supported?
Most QNAP, Synology, and ASUSTOR devices with a 64-bit x86 CPU, like Intel or AMD, and at least 2GB RAM are supported. We strongly recommend 4GB of RAM and an SSD for the Roon databases. Your music files can be on spinning disks, but ideally the Roon database should be on an SSD. This one optimization can provide the single biggest improvement to Roon’s performance and user experience."
https://help.roonlabs.com/portal/en/kb/articles/roon-server-on-nas#:~:text=Which NAS devices,and user experience.
This site was great to help get it set up.
Ideal is Roon Nucleus or Intel NUC with Roon Rock installed. A Synology NAS is a viable alternative, but not ideal.
Why is this ideal?
In the Roon community you will find all the answers. It is a question of power, for functions such as multi-room, the use of the integrated DSP, very large music libraries or the reproduction of DSD files at very high resolution, the demand for resources is very high.
I've never had an issue even when I tried pretty hard to choke it, but I'm sure there are those who might be able to make use of a separate computer.
Hard to beat the convenience of just using the NAS, and for me there have been zero hiccups fwiw.
I only just started to use Roon. I switched to it from JRiver after I set-up my A8. (I'm not fully convinced it's worth the money to be honest, but that's a different post.) At any rate, the server is set-up on the computer I use to store my file. I have around 161k audio files totaling just about 5 terabytes. I back-up onto external drives. (One-to-one harddrive to external drive). It's only been a few weeks but I have yet to find anything I'd want to do with Roon that I can't. I had thought, after all these years to switch to a nas for automated back-up however.
There is a hidden Gain control setting in the DSP that lowers the volume (-8dB) in my case according to source used even though DSP is not active. Quite annoying but you can remove this gain adjustment.
can you please specify which control you are referring to? thanks
This is a review and detailed measurements of the Eversolo DMP-A8 balanced DAC, Streamer, HDMI ARC, and Analog/digital Preamplifier with DSP support. It was sent to me by the company and costs US $1,980.
The DMP-A8 is stylish and functional in every sense of the words. Running Android with a high-speed processor, navigation is smooth and very rich. I am assuming the same CPU is used for DSP implementation of equalization, delay and compression as it works for all inputs (output must be analog however). The usual App is provided for the control but I was disappointed that a hard remote was not. Back panel shows the very rich connectivity:
Really, I can't think of a thing that is missing there. The DMP-A8 can easily be the heart of a modern system with support for legacy analog inputs as well.
Volume control provides excellent channel matching courtesy of stepped relay control.
Beauty extends to the insides:
There are many features available such as per input volume preset.
The unit was sent to me many months ago but I wanted to review it when Roon was implemented and it is now.
If you are not familiar with measurements that are about to follow, please watch my tutorial:
Eversolo DMP-A8 Digital Measurements
I streamed my reference test signal over Ethernet from Roon, capturing balanced output:
This is within shouting distance of state of the art stand-alone DACs:
Surprisingly, there is no hit to using RCA output:
There is a slight difference in dynamic range however:
Performance gets a bit better if you crank up the volume to max:
Multitone performance is superb:
As is linearity:
Jitter is nearly so and is input independent:
IMD vs level shows a slight rise in noise in mid-level but it is inconsequential:
Looking at the spectrum (not shown), noise floor moved up just a hair at -37 dB.
Driving an unrealistically low impedance of 600 Ohm doesn't bother the A8 at all:
Nor does it care what frequency you throw at it:
The DAC in use is AKM and we have the usual set of filters available:
Eversolo DMP-A8 Analog Preamplifier Measurements
I stayed with XLR input and output to keep the measurement set manageable. I selected volume control at 0 dB (it allows excursion well above that):
Wow! I was not expecting this. This is amazing performance. I thought it is digitizing the input but it is not (which sadly means DSP is not available for it either).
Across every measurement, performance is superb:
Reducing level to just 50 mv still provides excellent dynamic range:
That good noise performance translates into IMD vs level as well:
Making sure nothing bad happens when volume is reduced, here it is at -10 dB:
Crosstalk is superb:
And no frequency dependency:
In just about every area you look at, the DMP-A8 brings class leading performance combined with functionality that is not available elsewhere. All is put together in an elegant packaging with extensibility and openness of the Android OS. Critical features such as equalization and compression are provided. The only misses are lack of included hard remote and absence of DSP on analog input. The latter does translate into better performance than any digitizing analog preamp.
It is with my absolute pleasure to recommend the Eversolo DMP-A8 streamer and DAC. It is expensive but just doesn't get better than this folks.
Good morning amir.
I can't understand some measurements on this device.
In the SINAD test you write "maximum performance at 0db/4.4v".
Then in the preamp part test you write "I stayed with XLR input and output to keep the measurement set manageable. I selected volume control at 0 dB (it allows excursion well above that):
I would like to understand, but listening in streaming with this device, the maximum output reaches 4.4 volts, or can you also use the +10dB of the preamp gain?
Because I have this device but using it with the internal streaming features or its own files, it doesn't go beyond 0dB.
Sorry for the stupid question.
Thanks
Stefano
Is there any chance we will experience app problems in future because android becomes outdated?
It's literally one of the two most popular OSs out there and based on Linux. It's not becoming outdated for a long time.
@billou5767 I don't think I fully understood, but I think what you're basically saying is "It's fine, it'll work correctly". Is that right?
@Gyosa1 Interesting! I didn't know that was reported back. Cool.
Ive read this entire thread plus many more. I’m down the rabbit hole lol I need help.
I have a home theater system with separates, Anthem AVM70 and Monoprice 9X amp and Martin Logan XTs. I currently airplay Apple Music straight to the AVM but airplay is limited to 24/48. So I’m wondering how to implement a streamer to get better sound. Do I only use a streamer as a transport with direct connection to utilize the AVM dac so I keep room correction and bass management OR get a streamer with high end dac and bypass the AVM dac but that loses room correction and bass management. Uggg how can I get a better sounding 2ch with bass on my current system?? Is there a way?? Thank you guys in advance!
Hi,
I currently have a benchmark stack (DAC3B > LA4 > AHB2) driving a pair of KEF Reference 1s
was considering adding a streamer given increasingly getting more and more digital music
Would this A8 be a good solution to add to the system? or shoudl I look elsewhere?
Thank you!!
The A-8 is good but purely as a streamer a Wiim model pro ,pro plus/ultra would be cheaper and just as transparent.
