Eversolo DMP-A8 Balanced Streamer/DAC Review
Rate this streamer/DAC/Preamp:
    Votes: 8 1.7%
    Votes: 12 2.6%
    Votes: 89 19.2%
    Votes: 354 76.5%
I found someone talking about this a bit here, and it sounds like there's a problem with going below 50% volume using the HDMI eARC volume controls from the TV.
Anyone else experience this? And if so - could you modify the volume range in the device settings to help with this?
1/ perhaps its to have enough volume , its a base
2/ why think its eversolo ? the firmare its in tv too
Thanks Keith. How to find if it is clipping any idea? To my ears I cannot find anything weird (its my hearing observation). It could be easily that I might miss some small details due to clipping. Can I measure the output voltage of xlr output or RCA with reference level(using multimeter to check if the voltage is within the specification ?I tried to make a sweep with rew with volume level of 15, I cannot see any clipping in the data.
For MLP, i got an idea like i can sweep for multiple MLP and make an arithmetic mean to use for FIR, which will be still a decent representation of multiple MLP's. Will give try next time.
If it’s clipping you’ll know it when you hear it ..
Bk
Reactions: EJ3
2/ Those are good thoughts. My understanding of eARC / CEC commands here is that they are pretty dumb - they just communicate "volume up" and "volume down", and there's no reporting back to the TV what the actual volume is. That's why the TV UI doesn't give you a number. So it should be impossible for the TV to somehow have logic that causes it to stop working at a certain volume level, as it can't even know the volume level.
1/ that would certainly be a strange product decision to have this be a feature and not a bug lol
50 its middle of my sony tv , pioneer its 31.5 : under 50 i would have virtualy no sound : a lot a people destroy speeker with amp D to powerfull
by mistake can arrive between manipulation
when i cut amp the tv volume change from 50 to 24
the level are the same number , product are different : its a technical raison
My Sony tv displays the volume / changed on screen when connected to A8 via HDMI.
Bk
@mirror88 - Since A8 has DSP function, would it be possible to implement PEQ import function? This will be a powerful, as we can use some 3rd party app like Multi sub optimizer to optimize PEQ below lets say 300Hz. This means multi MLP can be achieved with robust optimization. One of my reason to switch from A6 to A8 as well is, my thought was it has PEQ import function like a minidsp but later found it don't. Since DSP is available in A8, I'm just curious why it is not implemented?
Hello everyone,
I apologize in advance if this is a basic question, but I would greatly appreciate any insights on an issue I've encountered with my newly purchased DMP A8.
I've connected the DMP A8 to my amplifier via RCA cables, and while the sound quality is excellent, I find that I need to set the amplifier volume to around 50-60% and adjust the DMP A8 gain to approximately -20 to -10 dB in order to listen to music from streaming services like Tidal at a reasonable volume. I don't mind these settings, but I'm curious if this is typical.
For context, I also have a turntable (Planar 1 connected to a Schiit Mani preamp and then to the amp), and with that setup, I only need to set the volume at around 25% to achieve a similar loudness.
Additionally, I've noticed that when streaming via Tidal Connect, the music is about 10-20% louder compared to playing the same tracks directly from the DMP A8. Has anyone else experienced this? What might be the cause?
Thank you in advance to anyone who can provide guidance on these matters.
There is a hidden Gain control setting in the DSP that lowers the volume (-8dB) in my case according to source used even though DSP is not active. Quite annoying but you can remove this gain adjustment.
The -gain adjustment is to prevent clipping after you implement filters.
Reactions: EJ3
Is the hardware in place to have the A8 outputs function as a crossover? In other words, balanced to speaker amplifier, crossed over, and an rca output to send lfe a sub? Would it be a matter of updating the software or is it not possible with the A8 as it currently exists?
I would add, also, is it possible to have the dsp work for the analog inputs as well?
The A8 uses a single Stereo DAC, so can only output two distinct analog signals, one for Left and one for Right.
You can do that but you would need a sub with its own eq/filter , no eq on the analogue input .
So I'm clear, I can set the xlr out put to send a signal that cuts-off at 40 hz but the rca signal will only send a full range signal requiring the sub to set the crossover? Or is it that however I set the dsp, it is outputted the same whether via rca or xlr?
At the moment you can only add eq to the digital inputs and outputs, the XLR and RCA outputs will have the same filtering.
So you would need filters on the sub.
I just bought an A8. But if to get full use of dsp you need to add another component, such as the Flex, and thus bypass the A8's dsp, I wonder if the extra cost of the A8 can be justified over an A6 and a separate pre-amp like the Kara. Remove the dsp and obviate the need for an analog input and there seems to be nothing to recommend the A8 over the A6.
I hate Monday morning regret but that's kind of what I'm feeling at the moment.
Adding the DSP mini flex would be a suggestion. You can run 2 subs and 2 mains set crossover freq and carry out REW settings. This is what I have and it works excellently. I do have an A8 but could see it would not do all the Flex can do. The A8 is one hell of a machine, easily worth the cost, no regrets here.
The EQ and DSP features of the A-8 work perfectly you just can’t use it to integrate a sub, the A-6 also has eq.
I'm looking at the DMP-A8 to potentially replace my first-gen Auralic Altair. I run a large library on a NAS via ethernet (180,000 tracks). My question :
Does anyone have any user experience with the built-in app, regarding managing and navigating a large library (searching by genre, artist, date added, etc...)?
