I have only compared to the Lumin mini, no difference, I haven’t found any sound quality differences, between WIim, Eversolo, Lumin, when used solely as a streamer.
I wouldn’t expect to.
Have you had any opportunity to look into any of my previously asked question?I have only compared to the Lumin mini, no difference, I haven’t found any sound quality differences, between WIim, Eversolo, Lumin, when used solely as a streamer.
So, no not same connector for downstream audio and upstream ARC.Introduced in HDMI 1.4, HDMI Ethernet and Audio Return Channel (HEAC) adds a high-speed bidirectional data communication link (HEC) and the ability to send audio data upstream to the source device (ARC). HEAC utilizes two lines from the connector: the previously unused Reserved pin (called HEAC+) and the Hot Plug Detect pin (called HEAC−).
I disagree. To my surprise, I’ve heard differences with different streamers before - even with the Eversolo A6 versus A8. I posted my thoughts in another thread, so I won’t repost there but you can see them here:I have only compared to the Lumin mini, no difference, I haven’t found any sound quality differences, between WIim, Eversolo, Lumin, when used solely as a streamer.
Post in thread 'Eversolo DMP A-8 compared to Eversolo DMP A-6 ‘Master’'
https://audiosciencereview.com/forum/index.php?threads/eversolo-dmp-a-8-compared-to-eversolo-dmp-a-6-‘master’.50124/post-1893927
Looks like a review unit to allow taking a peek at innards without opening up the case by everyone its sent to!DMP-A8 with acrylic top
24K views · 1.6K likes | Audiocostruzioni on Instagram: "Eversolo DMP-A8 Il DMP-A8 è un nuovissimo prodotto audio che combina Streamer musicale, DAP, DAC e Preamplificatore in un unico dispositivo. #audiocostruzioni #streamer #hifi #audio #hifiaud
1,665 likes, 13 comments - audiocostruzioni on March 21, 2024: "Eversolo DMP-A8 Il DMP-A8 è un nuovissimo prodotto audio che combina Streamer musicale, DAP, DAC e Preamplificatore in un unico di..."www.instagram.com
yesCan I use Tidal app on my PC to control the volume and tracks if the DMP-A8 is on the same network as my PC?
