They do as far as I know. They even have a whole SINAD chart from best to worst.
@kemmler3D gave me the idea to start this thread to get some good info out about application more than just simple products. Example: if I do go the modular approach, I need two things in particular to make everything work as intended:
1) Some sort of reclocker. Something that will help reduce lag time between boards and keep timings tight.
2) The microcontroller to conduct this whole symphony. RPi is definitely an option here. It has plenty of I/O and documentation for days on how to use it.
I also need to figure out where I'm going to put everything. More than likely the inside of the enclosure will be insulated. Electronics do not like heat.
