I mean... Hasselblad.
Zeiss, too... and Nikon (but I couldn't find any good photos of the latter).
Top photo is the Hasselblad “lunar data camera” with special back with the precision Reseau grid plate (thus the grids in all the lunar photos) with a highly modified 60mm Zeiss Distagon lens.
The specs for that camera, like the radios, instruments, and everything else that went on those flights were 0 to +/- 20 G’s for up to 3 mins, in any direction. A shock rating of 30 G’s (that would destroy pretty much any consumer electronic equipment, but anything that made it through that then has to survive a solar flare of up to 600 rads (which will fry all electronics without special covers) and then must operate (not survive, but operate) in temps from -186 to 115 C, and handle 100% humidity including condensation for 5 days from 80 to 125 F.
Like I said, the specs for NASA and FAA are pretty specific, vibration isn’t going to impact anything that is made and approved for aviation or space flight.
The bottom photo is Edward White, II on Gemini IV, on man’s first space walk (which about killed him from physical exertion trying to control his whackey propulsion system). That camera is a Robot brand camera, the model is the Recorder, also heavily modified.
A Nikon F (FTn prism) went up on Apollo 15, in the Command Module (which may be why harder to find photos?). Also heavily modified (fire proofed battery compartments, etc.).
There are some instruments that are very sensitive to vibration, like electron microscopes, some test instruments, and they are installed on Vibraplanes that null inherit vibration in buildings. Audio doesn’t seem to be impacted by it at all.
But all it would take is a Sonicare toothbrush set on top of the next 5 or 6 things Amir tests, on and off.
