The hundreds of millions of dollars that other people, (again, not me) spend on the myriad of tube amp company products would beg to differ! So does the seemigly endless rush to put a tube in components, even DAC's!EQ and tone controls are indeed often useful. But it has zero to do with whether you use amplifiers based on tubes or on transistors.
Its not about tonal quality at all. Tubes create higher order distortion. In effect they are a "less perfect" reproduction of the recorded material. To some, that is an endearing characteristic. Since the are less resolving, the difference between very good recording and more mundane ones is less stark. The very best tube amps everything sounds "pleasant" in the bad ones everything sounds flat nad unprecise. For tube aficionados its an endless search for the perfect mix to achieve that often elusive objective. Or, if you are very wealthy you buy an Audio Research referrence amp and thats it Even further complicating the matter and the hobby is that tubes in fact change over time! Though after burn-in ( a real thing with tubes) they perform to spec for years, then then they subtlety and progressively change till they fail. Tubes are a journey, not a destination! Aother endearing aspect of tubes is that they are suceptible to "microphonics." In effect, microvariations in signal that can be induced when musical feedback wiggles the tubes in their sockets! It's actually less common (and much cheaper to remedy) than the isolator salesmen would let on, but yet an additional "fun factor"
Personally I like my amp's AB in pushpull configuration with output tranformers to boot!
