Thomas Lutro
- Joined
- Apr 8, 2024
- Messages
- 20
- Likes
- 60
Hi
I'm thinking about making a new cable for my Sennheiser HD650's (needing a shorter one more than anything else.)
I've found some pretty 2 pin connectors on ebay, and thinking REAN (Neutrik-ish) 3.5mm jack for the amp end.
Though I'm not sure what constitutes a suitable cable. It looks like most people use some form of star quad mic cable? But is there any need for the screen commonly found on these? Or is this just making it stiffer and heavier than necessary? And LCR, does it matter in practice?
I guess a pair of cables held together with a braided sleeve up to the necessary split would be easier than stripping part of the outer sleeve and replacing it with two separate ones?
Would appreciate any tips.
