Not together yet (blue tape for photo purposes)!
Thanks for asking about this, as it's a chance to sanity check my decisions.
Here it is in cross-section, using Purifi's solid model of the driver. Their model has the space between the cone and the basket as a solid, so you need to ignore that portion of the violet crosshatch. The baffle (apricot crosshatch) is cut back to a thickness of 19 mm. Behind that (also apricot crosshatch) is a mounting ring that's 5-6 mm thick. The mounting ring mainly holds the nuts (not shown) for the mounting screws. Secondarily, It distributes loads and provides a secondary seal. But I think it would be fine to use six short segments.
Qualitatively, due to the large foam piece, the Purifi has a lot of space between the cone and the basket. So I felt comfortable with just the inset on the back. At the left and right edges, the inset comes right up to the inside surface of the enclosure.
Two questions for folks with more experience:
- Does this seem like enough space? And should I prioritize holding the nuts with six short pieces rather than the continuous ring.
