terryforsythe
@terryforsythe (or others) - Where does the 1.15 KHz from? (Had you not said that, I would have been asking what I should be looking for!)
1/2 wavelength corresponding to the hole diameter for a 6.5" woofer.
Does this seem like enough space? And should I prioritize holding the nuts with six short pieces rather than the continuous ring?
The prototype (5-ply big box store plywood) used a single layer of 1" thick shredded denim, folded to cover the sides, top, and bottom. I'm expecting to stay with that.Hi alan, what kind of damping materials did u use inside rhe cabinet?
Thank you! Though I'm not yet entirely happy with the black. I'm still struggling with those brush lines that you can see and feel...Exceptional work - mechanically (O-ring!) and the paint finish!
Thanks for that, @D!sco. Constant Sd is a bit different from what I was thinking.Purifi is happy to explain how their surround works. It’s about keeping all of their T/S parameters the same regardless of excursion.
It’s under Sd modulation.
Some Speaker Problems That Needed Solving
purifi-audio.com
