I (and some others) were tuning a friends home theatre yesterday. They use a monolith HTP-1 with Dirac bass control as their normal. All JTR speakers for base level and Revel C763L in ceiling atmos speakers.
Measurements were made using REW MMM and pink periodic noise to get spatial averages and an motu m4 interface and Earthworks microphone. Computer was a macbook pro 2018 model using either hdmi adpater out or out to motu m4. The htp-1 has a very cool signal generator option that you can output say left channel from your computer, then within the htp-1 interface, you can select the signal generator tab and the input is left signal input. Then you can route the output to every speaker connected one at a time. No need for asio4all or other things to get each channel to play individually. Saved a lot of time.
I wanted to compare the 16 band PEQ options in the HTP-1 to Dirac eq, as well as using smaart to look at phase.
Here is what I got from the experience.
1) Dirac as an EQ is pretty good. My PEQ and it's auto were very close and could easily be contributed to microphone differences and/or placement. Also the house curve choosen. I did a 0.5db / octave roll off as that seeme to match pretty well with natural roll off. In total actual time EQ'ing and measuring it would probably be about 5-6 hours for me. Dirac can do it much quicker with pretty good results.
Pre eq red, my PEQ green, dirac pink
Adjusted levels in REW to overlay my PEQ to dirac. Dirac did a very nice job here. Differences could easily be microphone placement or house curve used.
The one problem I have with Dirac is it cuts to the lowest speaker level possible (even lower than what my lowest natural level speaker was measured at as seen below). It won't boost levels at all. I choose, since the JTR's are plenty capable power wise and they are running on a D-sonic amp so not a power supplied issue either, to boost some of their levels up and then cut the others less to match levels.
This was the Highest speaker level vs lowest speaker level measured vs dirac levels, dirac clearly is cutting way too much: Note the red and pink lines are the same speaker just with no eq and then pink is with dirac turned on, no other changes. Orange line is one of the surrounds and was the lowest level measured speaker.
2) Dirac phase was wrong, I forgot to get measurements of this via smaart, but compared to what I got for phase using SMAART, it had the left and right delayed around 2ms difference and mine was a 0.3ms difference. The center was also delayed more than it needed to be in Dirac compared to mine. This was also evident listening to stereo music, the stage was biased heavy left. This could be due to the friend's method in how they took Dirac measurements previous. We just used their previous dirac stuff and didn't re-run dirac. So don't read a whole lot into this. Needs more investigation to determine if something is actually weird with dirac and phase.
Note* We did have a head in vice center image type situation with these JTR 212rt speakers when playing music, but as you can see from screenshots below the phase is very nicely lined up at the MLP. Shouldn't really be an issue for a home theatre, but wouldn't be great for just listening to music, but music doesn't really seem like JTR's main goal. Speakers are toed in to be angled at MLP, so we may play with this to see if we can widen the sweet spot.
This was my phase graph with a 0.3ms difference
LCR SMAART
3) The revel C763L speakers are awful. Don't buy them. Clearly issues in all 4 around 2-3000hz range. Not fixable issues too. I, and others, are guessing this is from the MTM design of it since the mids cross to the tweeters around 2000hz according to revel. I was shocked how bad these measured in room.
LCR SMAART
