Hello Kal, I assume aside from using JRiver/plug-in with DL, you have also run it just with Windows. If so, may be you can help me again.
I signed up to Beta test DLBC page's instruction, using the PC standalone version, so far I managed to get the screen similar to Dirac's:
confluence.dirac.services
When I proceed to the next step, that is to "calibrate", something strange happened, after the sweeps, left, right worked as expected but subwoofer output 3 appeared to be exactly the same as left output 1. Subwoofer Output 4 appeared to response as expected. I double checked my windows configuration and didn't see anything unusual.
I created a ticket at the helpdesk but unless
@Flak happens to be the oner handling the ticket, I am not sure if they could help me quickly enough. It usually took a day to several day for them to respond anyway so by the time they understood my question and suggest solution, it could take a long time. So I thought I would try my luck here, may be you, or Flak can help me solve this puzze.
I am trying the Beta on my HT setup for now as you know I don't have a multi-channel DAC yet. So I got my Mcbook pro connected via HDMI to an input on may AVM70 and configured that input for 2.2, left, right, sub1 and sub2, for now. And obviously I set Anthem Room Correction for that input to off.
