- Joined
- Aug 14, 2018
- Messages
- 2,773
- Likes
- 8,155
This actually doesn’t represent a change, this is how I thought it worked from the get go. That each of the four slots represents a complete configuration. What threw me for a loop was people saying that it was wrong that I had Dirac 1 assigned to both Left and Right.
I did two sets of measurements, Slot 1 was with the 0degree mic cal and Slot 2 was the 90degree cal. I wanted to see if using a different mic cal would clear up my issue and it didn’t.
People were saying that because it is indeed wrong. Here it is direct from MiniDSP:
Under the heading of each Output - which is one channel - the green box says which input is being routed to that output. So if you have two channels, Input 1 should be routed to Output 1 and Input 2 should be routed to Output 2, as I've outlined in red here.
I understand your setup says "Dirac 1" in the green boxes instead of "Input 1" - but see the bottom note from MiniDSP, which I've also outlined in red: Dirac automatically renames the input channels to "Dirac" instead of "Input."
The same concept is referenced in MiniDSP's instructions for doing Dirac calibration - during the calibration, the left speaker is listed as Dirac 1 and the right speaker is listed as Dirac 2. Here's a sample screenshot from the volume calibration step - note how they refer to Dirac 1 and Dirac 2. both are part of the same stereo calibration process and the L channel/speaker is clearly labeled as Dirac 1 and the R channel/speaker clearly labeled as Dirac 2 - the whole point there is that you need to ensure that the output of each speaker/channel - Dirac 1 and Dirac 2 - is being picked up by the UMIK mic at roughly the same volume level.
So "Dirac 1" should only be listed under Output 1. Dirac 2 should be what's listed in the green box under Output 2.
Finally, regarding PEQ - yes, that's independent of Dirac. However, if you create a Dirac filter/setting, and you also apply some of your own manual PEQ through the MiniDSP's PEQ functionality, that Dirac filter and those PEQ adjustments will both be saved to whichever of the four MiniDSP presets you choose - and only to that preset.
If you disable Dirac but stay on that preset, then the PEQ settings will still be active. If you disable Dirac and also switch to another preset, then both Dirac and the PEQ will be disabled.
