No, I don’t use the d10 as a dac, I use it to feed digital signal into a 6 to 8 dsp which then contains a dac (as listed above) to give 8 outputs of analogue to my amplifiers running 3 way plus sub fully active
I have compared the d10 as a dac to the d10 as digital into my dsp and digital sounds way better!
I am enquiring as to why amir doesn’t test the digital outputs of devices which have digital output (like the D10 for example) as digital usb to digital coax or optical outputs when he tests the unit as a dac, and if so how and what can set different digital converters of this kind apart... as I have had markedly different results from two devices which are both digital converters for usb digital in... the topping being superior (this is not what I was referring to earlier when comparing digital vs analogue which was purely the topping via two different outputs)
