Does a local Magnolia have a way of acquiring one from another that may have it in-stock?
Accessories4Less is also sold out, so I may just end up getting a refund and trying to hold on until the x3800h comes out.
It will probably end up better for you in the long run, given that at some point you will run into the HDMI 2.1 bug. Sorry this happened to you, but it happens. The 3800 will probably be the same unit with "fixed" HDMI ports.
The plot thickens: When I try to access the denon settings while connected to eRAC I'm now seeing a connection error most of the time. So somewhere an HDMI handshake is failing. I really hate the idea of sending back receivers and TV's to try to rootcause which one it is.
It's funny because if I go back to the TV the ARC functionality works and I can get the TV sound into the AVR but it seems to flake out when I try to access the AVR settings. I'm starting to wonder if the receiver turning off could be a CEC issue.
Does it on my TV too, I figured it was a bug. Switching to another source on the AVR fixes it. Go to CD and then you get the settings show upThe plot thickens: When I try to access the denon settings while connected to eRAC I'm now seeing a connection error most of the time. So somewhere an HDMI handshake is failing. I really hate the idea of sending back receivers and TV's to try to rootcause which one it is.
Bull, how is your U8G doing still, I’be been eagerly awaiting its release (or equivalent) here in Australia, any niggles so far with the picture ? Sorry to Hijack thread .
@ciotime : Hi, I'm exactly in the same situation: I'm about to buy this Rotel 1582 MKII and a Denon AVR-X3700H but I'm concerned about this input sensitivity voltage issue. What did you finally do and why?With regards to choosing an external amp to power the Denon X3700H I've been told that it's very important to get one with a specific sensitivity that will match the Denon's pre-out voltage gain. Saw this review and I quote " As you see, peak performance with the amplifiers off is around 1.1 volts with SINAD of 101 dB which is excellent for an AVR. With the amps on, you are OK up to 1.4 volt output before it nose dives. So when selecting an external amplifier for channels beyond fronts, make sure it can output its maximum power at or below 1.4 volts (usually specified as "sensitivity"). " I never knew this until I asked someone if getting the Rotel RMB1585 was a good idea to use as an external amp. The INPUT SENSITIVITY is as follows: Line Level Inputs (RCA): 1.9V / Line Level Inputs (XLR): 3.8V. 1.9V is WAY above the recommended 1.4 volt. Am I correct that I should choose a power amp with an Input Sensitivity of 1.4V or lower? IF an input voltage to an amp is less than it's rated sensitivity, the amp will not come close to amplifying the signal to it's rated wattage. SO, if I use the Rotel, it most likely will make less output wattage per channel than just using the Denon alone and there is no point in spending money on an amp that actually makes less power than the AVR that it's connected to. Or will the Rotel RMB1585 paired with the X3700H be fine? I plan to externally power just the 3 front speakers and just let the Denon handle the other surround speakers. Setup is 7.2.4.
My front speakers need a lot of juice and therefor I want to use the Denon AV as a preamp and drive speakers (Focal Aria 936 = 300W at 8ohm) with a powerful amp.
Is this output voltage automatically adapt to the connected power amp? Or does it vary depending on the volume on the AV receiver? I don't understand quite well this point....The Denon can output 2 V very cleanly and could go much higher, more than 3 V for sure without clipping.
Thanks for your reply.
Also, according to @amirm test, the SINAD performance drops beyond 1.4V (best perf is at 1.1V).
It's not about sitting close or far: the thing is, the front speakers really need a lot of juice to make them sound fully and make the 3 woofers correctly "breathe". I had previously an Onkyo RZ900 with 145W at 8ohms and when I had for test this Rotel it sounded totally different, event at the same volume. To me it's not about dB, it's about how plenty and fully bodied are juiced the speakers.
Not mentioning that when watching movies in 5.1 the Denon power will be splitted and for sure will poorly drive the front speakers.
To follow up on my previous issues with the Denon restarting, I unplugged and re-plugged it in last Saturday after it happened and it hasn't happened since. When it was initially plugged back in the first time following the lighting storm, I had the Mrs do it, and maybe the connection was slightly weak.
I am still having some goofy audio issues though that are hard to nail down between the TV (source) and the receiver. I was watching a movie on Hulu last night and the sound suddenly cut out and the video kept playing. Exiting the app didn't fix it and I lost all menu sounds on the TV and re-entering the app didn't resolve it. A power cycle and everything was right again.
Another thing is that now my speakers will every once in a while make a pop - like the sound of popping a single bubble on a small bubble wrap sheet but higher pitched. It usually happens (or at least is noticeable when audio is quiet or even not actively playing - like on the TV menu). It seems to only happen once or twice during a listening session, but it's noticeable enough to be concerning. It never happened with my previous receiver, but that was also with a different sound source so maybe it's the TV, maybe it's the receiver, or maybe the speakers were slightly damaged in the lightning strike.
