I have issues with these spl calculators. How do they take into account for swinging impedance levels and electrical values as phase. Hard amp draws at certain frequencies. It just seems very generally speaking there are a lot more variables then efficiency distance and wattage on the calculators. Not all 89db at 2.83v speakers are created equal.
True, that's why if in doubt, take 3 dB off the specified sensitivity if it is stated X dB/2.83V/1m, then it should be enough to allow for those 3 to 4 Ohm dips. Of course some speakers have worse phase angles than others, but phase angles usually are not much of an issue for electromagnetic/moving coil loudspeakers. In the Stereophile review, the phase angle wasn't too bad except in the 650 to 2 K range where the impedance was about 4 Ohms or higher. The MM7025 should have no trouble with that but it still depends on the spl and distance, that's why the OP should use the calculator to figure out his power need first. To avoid overheating due to large phase angles (especially if coincide with low impedance), I would put a fan on top, in fact I do that regardless.
