watchnerd
I am holding on to my 20+ year old PCM63 DAC! I'll try to measure it one day, once I dig it out from storage
Original packaging, I hope!
Discrete R2R DACs have termo-EMF performance leak.I have a modern R2R DAC as well.
Gaussian (normal) distribution codes for noise. Linear distribution for triangle.What "statistical characteristics" are spoiled?
I still think we are being played here...
What are you talking about, I can hear a needle fall just fine while standing next to an F22 during take off.The ones at -142.5 dB? In response to -100 dB output and below? Seriously? The spectral distribution of quantization (and other) noise is quite different for delta-sigma designs. You could just as easily say that, since the noise floor of the DX7s is much lower than the ML 360 between 192 and 196 Hz, that the DX7s is a much better design.
Actually the Topping has better linearity. The peaks snapped to every 5dB grid closer than the Mark Levinson.The ones at -142.5 dB? In response to -100 dB output and below? Seriously? The spectral distribution of quantization (and other) noise is quite different for delta-sigma designs. You could just as easily say that, since the noise floor of the DX7s is much lower than the ML 360 between 192 and 196 Hz, that the DX7s is a much better design.
At medium and high frequencies, the results should be worse.In response to -100 dB output and below? Seriously?
According to unverified information, scientific (non-audio) true 20-bit ADCs (1997yr) and 24 bit DACs are made on heat-conducting ceramic boards and placed in a thermostat.I'm familiar with the temperature effect on a ladder
If you set a goal to use the SAR ADC to identify all the D-S DACs errors (artefacts), then it is possible, but this website will cease to bring advertising to mainstream producers.
https://www.baspi.ch/low-noise-high-resolution-dac
Ceramic also: https://news.thomasnet.com/fullstor...rk-is-designed-for-a-d-d-a-conversions-478945
For frequencies < fs/2 the NOS filterless DAC is perfectly accurate (Ok, there is some attenuation towards fs/2 caused by the sample and hold).
All inaccuracies are in the folded spectra >fs/2. If the rest of the system does not make any new signals out of these in the <fs/2 range, and the ear perfectly ignores all of these folded spectra, a NOS dac could sound ok
How is this thread 16 pages long and growing anyway?
Amplitude modulation?Incorrect. It does NOT adhere to the sampling theorem at all. It needs a reconstruction filter for that to happen, soft/firm-ware and/or hardware.
Audible frequencies above 5kHz are amplitude modulated which is what causes the 'roll-off' its not similar to an RC roll-off.
Ok, I dont think so, I will do a simulation to see if you are right, but to my knowledge a 10Khz tone out of a NOS DAC will have a constant 10KHz component attenuated by -0.7 dB and a lot harmonics above Fs/2.
Do you have a reference to that amplitude modulation?
