I listened to this on my Harman EQ'd Hifiman HE4XX just now, and it seems fine.....there is a hella lotta energy coming from the Hi-Hats though so that might be what's bothering you. Actually one thing I've done differently with my HE4XX (yesterday & which might be relevant to you) than I have with my other headphones is that I smoothed out 4-8kHz to remove "waviness" (peaks) when running through a slow sine sweep from here (https://www.szynalski.com/tone-generator/ ), and I know from listening to the same sweep on my EQ'd Anechoic Flat 308p speakers that my normal hearing is free of any waviness and peaks in the 4-8kHz zone, yet there were some annoying & obvious peaks I identified at 5.5kHz, 6.4kHz, and 7.5kHz which I was able to smooth out into the surrounding areas by applying Peak Filter cuts at those points.....I'm very impressed with this HE4XX now as I always found it had an annoying uncomfortable quality somewhere, but I think I've found out what that was now. In fact here's the frequency response graph showing the green circled part where I cut the response to below the blue coloured Harman Target during my listening testing: . My other headphones don't need cutting below the Harman Target in this area, so it's either unit to unit variation or the HE4XX reacts differently on my head & on the GRAS unit than my other headphones do. It could be that the Stealth is reacting to your anatomy differently in that area too. If you are gonna do the sine sweep experiment that I did then you'd be best off listening to some anechoic flat speakers with a sweep first though, because your natural hearing might have peaks in some places which you wouldn't want to correct - for instance I have a massive natural boost to my hearing from 8-12kHz (weird!), so I wouldn't want to correct for that broad peak in headphones (or speakers).@amirm does this track sound loud/annoying to you in the 2-4 kHz range when listening through the Stealth?
I find this one hard to listen to with the Stealth (the entire album really), particularly after the 8:00 mark. Much better if I drop that frequency range by 2-3 dB. However, I can see in the spectrum that this range is quite elevated in the track, so maybe it is badly EQed rather than my hearing or the Stealth off.
