So what you’re saying is that the track would sound better with a BBC dip? You’re going to give the Harman curve worshippers a heart attack.Thanks @Doodski, @Robbo99999, @RHO and @Jimbob54 for your impressions. Sounds like everybody here can hear some issues with this track.
The spectrum here looks like the 2-4 kHz region is significantly elevated compared to tracks that sound better to my ear, and coincidentally, lowering this region by 3 dB or so makes it a lot more pleasant to listen to. With our ears being the most sensitive in this region, having a local maximum there seems... questionable.
I am saying this is how Lateralus sounds much better to me:So what you’re saying is that the track would sound better with a BBC dip? You’re going to give the Harman curve worshippers a heart attack.
I don't think it's a fault of the Harman curve per se, the spectrum clearly shows 2-4 kHz being elevated and combined with our ears being the most sensitive there, it seems plausible that accurate reproduction of this sounds wonky. I think a headphone with a dip in that area sounds much better on "properly" EQed tracks than a Harman target headphone does on a badly done one. Both are effectively off target, but being 3 dB low is much better than being 3 dB high there.
Spectrum as found on CD:
After EQ:
I do indeed. How easy is it to find ones that want to pull weeds, wash our van, help with canning a ton of fruit and vegetables, and finish the electrical wiring in the woodshop? Then, I will feel less guilty about continuing to test audio gear a the rate I have been doing!Amir needs some interns ; )
Sorry, just got a chance to listen to it. Yes, towards the end, the highs are a bit much. But wouldn't it be the same in a concert of theirs, sans the distortion that they live system tends to have?@amirm does this track sound loud/annoying to you in the 2-4 kHz range when listening through the Stealth?
I find this one hard to listen to with the Stealth (the entire album really), particularly after the 8:00 mark. Much better if I drop that frequency range by 2-3 dB. However, I can see in the spectrum that this range is quite elevated in the track, so maybe it is badly EQed rather than my hearing or the Stealth off.
I have the open back Aeon 2 and can hardly find a review on its well. Would to see that review, but alas...don't see that being requested at all so little chance of that happening.I don't want to fix anything, just would like to see the open back DCA gear get looked at by Amir.
Believe me, even if it measures like crap, I will still enjoy it. I just like open back headphones and am curious how it measures up to Dan Clark's closed models.
Ah, I see, you've only got 5 parametric bands of EQ to play with when using the ADI-2 DAC, yes and my 3 High Shelf Filters would only leave you with 2 extra filters for headphone EQ. In that case, you'd be better off using my first iteration of the Tone Control Filter that @Jimbob54 mentioned, which is just one filter: High Shelf 982hz Q0.2 . That will actually be more effective (& legitimate) as a general tone control than your idea of using one of your filters for taking down 3kHz by a bit - afterall both options only take up one parametric filter slot so nothing lost from that point of view.If I ever switch to software EQ, I will give this a try. For now I stored an extra profile in my ADI-2 DAC that drops 3 kHz by a bit in case I come across another very bright/"loud" recording. I am generally very tolerant when it comes to treble and have treble control on the DAC anyway.
For the Lateralus album, I tried setting up a dedicated PEQ that sounds way better and I might use to create a "fixed" copy in the future. Unprocessed Lateralus sounds much better with the Ether 2 than the Stealth, the Ether 2 is quite low around 3 kHz, which really fixes the guitar harmonics yelling at you. I think a slight weakness in this area might be desirable over being perfectly accurate, it is much more compatible with questionable sounding music.
Don't sound too bad to be honest, there's worse jobs!I do indeed. How easy is it to find ones that want to pull weeds, wash our van, help with canning a ton of fruit and vegetables, and finish the electrical wiring in the woodshop? Then, I will feel less guilty about continuing to test audio gear a the rate I have been doing!
Well I hope that is not quite how it sounds like in concert. This album sounds like it was made to sound "correct" with gear that has recessed upper mids and we're listening without recessed upper mids. Does it sound better to you when you EQ -3.0 dB at 3 kHz, Q 1.5 on your ADI-2 DAC? I find that listening as is, loud parts are dominated by random guitar harmonics that I cannot connect to a fundamental anymore.Sorry, just got a chance to listen to it. Yes, towards the end, the highs are a bit much. But wouldn't it be the same in a concert of theirs, sans the distortion that they live system tends to have?
And what do you think of the low frequency reproduction? I find it quite nice even on this track and the first track in the album.
I don't need a tone control as much as I need something to that undoes people undoing a BBC dip in their monitors, though. Treble > 5 kHz rarely bothers me.Ah, I see, you've only got 5 parametric bands of EQ to play with when using the ADI-2 DAC, yes and my 3 High Shelf Filters would only leave you with 2 extra filters for headphone EQ. In that case, you'd be better off using my first iteration of the Tone Control Filter that @Jimbob54 mentioned, which is just one filter: High Shelf 982hz Q0.2 . That will actually be more effective (& legitimate) as a general tone control than your idea of using one of your filters for taking down 3kHz by a bit - afterall both options only take up one parametric filter slot so nothing lost from that point of view.
That's assuming that is indeed the problem (I've seen your graphs), but I'm not convinced of the interpretation. General tone control filter is gonna be better than relying on a 3kHz reduction when it comes to tuning headphones & speakers on an album by album basis in terms of solving "Circle of Confusion" issues.I don't need a tone control as much as I need something to that undoes people undoing a BBC dip in their monitors, though. Treble > 5 kHz rarely bothers me.
Yes there areDon't sound too bad to be honest, there's worse jobs!
The judge was quite clear. No internsAmir needs some interns ; )
This track sounds harsh in the upper mids and lower treble. Listening on Focal Elex EQ'd to Harman from RME ADI-2 DAC FS, and Sennheiser 660S EQ'd to Sonarworks from JDS Labs Element II. I don't think it's your new headphones.@amirm does this track sound loud/annoying to you in the 2-4 kHz range when listening through the Stealth?
Thanks. I remember this album being problematic with my Focal Clear and Sonarworks TrueFi active.This track sounds harsh in the upper mids and lower treble. Listening on Focal Elex EQ'd to Harman from RME ADI-2 DAC FS, and Sennheiser 660S EQ'd to Sonarworks from JDS Labs Element II. I don't think it's your new headphones.
I'll give it a try tonight.That's assuming that is indeed the problem (I've seen your graphs), but I'm not convinced of the interpretation. General tone control filter is gonna be better than relying on a 3kHz reduction when it comes to tuning headphones & speakers on an album by album basis in terms of solving "Circle of Confusion" issues.
Do you still have the Clear and have you done any A/B with the Stealth?Thanks. I remember this album being problematic with my Focal Clear and Sonarworks TrueFi active.
In a different continent, so not accessible. It fell a bit out of favor with me when it lost more and more lower bass. I would expect it to sound very different.Do you still have the Clear and have you done any A/B with the Stealth?
Im going full on subjective here but to my ears the Clear is pretty fragile/ brittle sounding. Great for detail but bass heavy (even with some EQ) it aint.Do you still have the Clear and have you done any A/B with the Stealth?
