D-Sonic M3a-600M Class-D Amplifier Review
Rate this amplifier:
    Votes: 102 45.1%
    Votes: 113 50.0%
    Votes: 10 4.4%
    Votes: 1 0.4%
This is a review and detailed measurements of the D-Sonic M3a-600M Class-D monoblock amplifier. It is on kind loan from a member and costs US $1,175.
Packaging is a step above "DIY"/budget class D amplifier with heavy gauge steel all around. It also weighs more than amplifiers in those classes. Back panel shows balanced input and trigger which is appreciated:
D-Sonic M3a-600M monoblock amplifier pascal X-Pro class D back panel XLR trigger review.jpg
Company doesn't state the origin of its class D design but a review says it is based on Pascal X-Pro series. Many OEMs uses these modules for their reliability and high power capabilities. To wit, the spec for M3a-600M calls for 800 watts into 8 ohm despite the name indicating otherwise.
D-Sonic M3a-600M Measurements
Let's start with our dashboard of 5 watts into 4 ohm load using XLR input:
I was disappointed to see such high level of 3rd harmonic in this day and age. That dominates SINAD, delegating the amplifier into our "fair" category of all amplifiers tested to date:
Zooming in:
Amplifier gain is quite high at 31 dB which is a likely contributing factor to even lower performance with RCA input:
Now noise dominates. I played with different grounding methods but that was the best I could get.
Naturally, that reflects into our SNR measurements:
Not a good showing but situation improves at full power:
Frequency response is very good for a class D amplifier:
D-Sonic M3a-600M monoblock amplifier balanced frequency response measurement.png
Multitone shows increase in distortion with frequency:
Which naturally is also reflected in our 19+20 kHz intermodulation distortion test:
D-Sonic M3a-600M monoblock amplifier 19 20 kHz intermodulation measurement.png
Product's claim to fame is power and on that front, it delivers:
But at noted, distortion sets in early. I checked Pascal spec (inset) and it is only a bit better than what I am measuring.
Protection circuit is robust and strong but at the same time, it didn't allow me to get reliable max power. But did work for peak power:
D-Sonic M3a-600M monoblock amplifier balanced Peak Power 4 ohm measurement.png
That is hell of a lot of power!
We get good bit of power at 8 ohm as well:
I was impressed with amplifiers ability to produce lots of power into high frequencies -- many amps have trouble here:
D-Sonic M3a-600M monoblock amplifier balanced Power 4 ohm vs frequency vs distortion measurement.png
The backward excursion of the graphs shows the amplifier protection circuit. We can see in excess of 600 watts before that happens above 500 Hz.
Warm up was uneventful:
There is likely power off pop however:
The amplifier finished the measurements with its bottom plate pretty warm. Considering how much power it has though, that is to be expected. Be sure to not stack it on other amps.
Story here is pretty simple: noise and distortion is below par by some 10 dB. But you have tons and tons of power. You all need to do the math for me as far as value relative to the power it produces. A way to look at this amplifier is that it is like a "Pro" amplifier but with no fan with 3 to 4 times higher cost.
I personally can't recommend the D-Sonic M3a-600M due to high level of distortion and noise (in unbalanced). But you may decide otherwise if you want a branded amplifier with lots of power.
Just buy a pro rack mounted amp for half the money? These modules are aimed at pro audio, so I'm sure you can find a rack mounted amp using them.
Thanks, @amirm ! :)
Very powerful, but clearly not that clean. In fact, very noisy.
Doesn't seem like it, at least on pictures. :confused: For this price class, I would have expected something more... appealing.
Pic of the inside:
Edit : shared by @daniboun above.
I would vote fine by power alone but that 20Hz behavior and performance is not convincing at all.
Thanks Amir!
Looks like it's limited by the protection circuit (possibly together with anti-DC) At least there's no fear of quality loss, up until 317W into 20Hz sine wave anyway. With real music it's doubtful the integral of the waveform would reach a value high enough to trigger.
Depends how you use it.
At this thread there's a good example of an LFE signal (from Interstellar) which can bring down an amp to it's knees if used for subs,etc.
For similar money one can get a Hypex NCore NC2k based amplifier from VTV that has much more power while also better noise and distortion levels.
Edit: measurements from the Apollon amp using the same module and power supply, so it should be identical to VTV.
I can't help thinking it looks inadequately cooled for sustained output, given the steel case won't help much. The module datasheet doesn't say much about it beyond the fan and protection trigger temperatures. I assume there is no fan in there (no sign of one in the internlal pics, but could be bonded inside the lid I suppose.)
Can't tell by the height but fan could be underneath the module too.
And it should,even if the whole case acts like a heatskink it's a joke for this kind of power.
Edit:Also feet does not seem fit for the application.
I have seen melted ones in similar arrangement,rubber should not be used when case acts as a heatshink.
I voted not great...
However, I must say that I know someone who has had a pair of these Pascal modules purchased ready-assembled in the United States and delivered to France for many years now, 8 or 9, and who uses them to power a pair of Revel Salon 2... These are therefore already old modules and we can imagine that the manufacturer has improved certain points on the successor of this module (if there is one! = PS he just told me that there have been two or three generations since then.)
With him the listening is magnificent from all points of view in a treated acoustic which allows you to appreciate these magnificent speakers without hindrance. We had compared a DAC Topping DX3 Pro + and a Gustard at his place, the reference of which I have forgotten but sold about four times more expensive and which also had excellent measurements, levels carefully equalized and had not been able to establish the slightest hierarchy if indeed we were able to differentiate the two DACs...
It's a Headless Panther.
The market comparable for this amp is the latest generation of Purifi Eigentact monos from Buckeye amps
Which one would anyone here rather have?
Not competitive with offerings from Buckeye and Apollon. Probably below hearing threshold for distortion, yet still I don’t like the measurements. Thank you Amirm for returning in full swing with the flow of reviews!
Even the power output doesn't justify that price. You can get a Hypex UcD2k monoblock for $800 which does an honest 2000 watts, and Hypex specifically notes it is suitable for subwoofers so I assume low frequency performance is good.
Reactions: VQR
I was always curious how these tested... for some reason they are exactly what I predicted: powerful but not very clean. I think my next amp will be an Apollon NCx500ST. That seems like a sweet spot.
