Got my pair of G-horn last week, and have been fighting against their hum for that long.
Long story short I recently lowered the power of all amps of my active system after having measured the real voltage used.
So mids and highs only need 5 & 10 watts for insane levels, while mostly cruising between 0.01 and 1 watt.
Tried few affordable amps, of all class, and they all had something wrong (hiss, buzz, hum, bugs or usability issue).
The last were the iotas PA3, that are not supposed to be the best on paper, but they are the cleanest in my case with none of these issues.
(now honestly I have no idea what to look at on amp specs for low noise: I don't see any correlation)
Anyway I was still curious about a kind of "first watt" amp, and wanted something smaller to fit in the rack.
Studied some diy options and was about to pull the trigger when Schiit launched these.
I figured it would still be cheap while faster, and they had everything on paper to be the solution.
The first smile disappeared quickly when I plugged them, classic transformer hum with just power on.
I don't know enough but assume it's not DC related as the iotas are silent in the same spot.
It's not dramatic, no more than what I've experienced before, but still too much for my setup and taste.
They also hiss on midranges (98db), very low so not an issue, but the iota was dead silent there.
After a conversation with Schiit I decided to not return them (kind of moot from France with taxes and double shipping) and see what I could improve.
So, opened the little guys and tried few things.
On the bench, putting the transformer on a simple cloth outside the case reduced the noise a lot, to barely audible.
I don't know enough but it seems it could be some loose wires that are vibrating?
This was the way to go, reduce vibration by dampening anything I could.
After few tests I ended up placing a ring shaped piece of felt under the transformer, moving the pressure at the bottom circumference instead of the center pad.
This raised the transformer a bit so I also added a piece of rubber to make sure to isolate the nut from the cover.
Plus some thin rubber between sides and cover to raise it to avoid pinching the wires, while reducing vibration transmission.
And some very soft feet below.
Good result, I can still hear it off few cm, but not at 1 meter.
Kind of happy ending, not what I originally expected but they still have enough value to my eyes ears to keep them.
And I’ll try to recycle the two pa3 on the mid-bass.
So far the sound is good, nothing lacking in terms of headroom, stage, details, etc, one per side so no stress on such bandpass.
I have not been over 1 watt yet (95db+ territory) and very rarely do anyway.
I got my smile back.
I'll see from there, thought about changing the transformer for an audio grade one fully dipped in resin maybe, or smps.
Might even put them in a new case one day.
Or do you guys have any other trick?
