Cobalt Blue Dragonfly DAC by Audioquest/anyone tried it?
Lounge Lizard
B"H Hi, I'm thinking of buying the Cobalt Blue Dragonfly DAC both for my smartphone but especially for my headphones at home. Has anyone tried these? Are they worth $299? Thank You
SIY
Alfred, NY
I’ve only tried the Lightning version, and it performed terrifically. I think Amir tested the Android version.
SIY
Alfred, NY
Other one I use regularly is the CEntrance DACportable.
Are you saying that an apple dongle will do the trick? But I'm on android and need a DAC for Samsung smartphone/and home headphones Sennheiser 195
The Apple dongle unfortunately is not very compatible on Android. On my Samsung S8+ for example, it has very low volume and I hear the same complaint from others.
Your headphones are wireless, no? If so, they have their own amplifier so all you need is a DAC, not a DAC+headphone amplifier which these devices are.
Lounge Lizard
Lounge Lizard
Thank You Amir
Hemi-Demon
The ibasso DC01 is a excellent, cheap device. Although its 2.5mm, only for now. The 3.5mm version hasn't been released yet
Lounge Lizard
Lounge Lizard
ב"ה Amir, your input is priceless! Thanks
Cortes
VintageFlanker
Paris
More words of wisdom of Darko
The AudioQuest DragonFly Cobalt (US$299) sounds far better than the average smartphone’s 3.5mm output
https://darko.audio/2019/11/more-thoughts-on-a-beginners-guide-to-dacs/
notice how with great skill he says 'than the average'...
Another piece
A DAC loaded with tubes might lend the overall sound more ease or a fuller, fatter tonality
again 'might'.... and later introduces all the commercial propaganda.
Absolutely everything sounds far better than the average for Darko...
JJB70
Singapore
Darko doesn't even have the entertainment value that makes some reviewers good fun to read or listen to.
