Lounge Lizard
- Joined
- Aug 10, 2019
- Messages
- 22
- Likes
- 4
B"H Hi, I'm thinking of buying the Cobalt Blue Dragonfly DAC both for my smartphone but especially for my headphones at home. Has anyone tried these? Are they worth $299? Thank You
Thank YOU. What might be good as a portable DAC for my smartphone and also to power my Wireless Lossless Sennheiser R195 headphones?Recent measurements by Archimago says no. Don't buy it.
Are you saying that an apple dongle will do the trick? But I'm on android and need a DAC for Samsung smartphone/and home headphones Sennheiser 195Apple dongle.
ThanksI’ve only tried the Lightning version, and it performed terrifically. I think Amir tested the Android version.
The Apple dongle unfortunately is not very compatible on Android. On my Samsung S8+ for example, it has very low volume and I hear the same complaint from others.Are you saying that an apple dongle will do the trick? But I'm on android and need a DAC for Samsung smartphone/and home headphones Sennheiser 195
Thank You AmirThe Apple dongle unfortunately is not very compatible on Android. On my Samsung S8+ for example, it has very low volume and I hear the same complaint from others.
Your headphones are wireless, no? If so, they have their own amplifier so all you need is a DAC, not a DAC+headphone amplifier which these devices are.
ב"ה Amir, your input is priceless! ThanksThe Apple dongle unfortunately is not very compatible on Android. On my Samsung S8+ for example, it has very low volume and I hear the same complaint from others.
Are you sureThe ibasso ..... The 3.5mm version hasn't been released yet
Absolutely everything sounds far better than the average for Darko...More words of wisdom of Darko
The AudioQuest DragonFly Cobalt (US$299) sounds far better than the average smartphone’s 3.5mm output
https://darko.audio/2019/11/more-thoughts-on-a-beginners-guide-to-dacs/
notice how with great skill he says 'than the average'...
Another piece
A DAC loaded with tubes might lend the overall sound more ease or a fuller, fatter tonality
again 'might'.... and later introduces all the commercial propaganda.
but...Darko doesn't even have the entertainment value that makes some reviewers good fun to read or listen to.
Right after seeing this, I asked to @amirm if he could measure any difference with this "tweak", at the time he had the Modi 3 for his review. Sad he couldn't do that. But Audiophiles would have answered: "measurements don't tell the whole story" anyway...but...
