A follow up to a couple of post's I made.
The Paiyon P82 I have a Chinese video site which has a recording of various music being played (and you will notice on the right side has many other clips of other Chinese speakers) so worth a look and another which shows the specs and quality of the P82se cryo version. I want to stress I have nothing whatsoever to do with this company. It looks like for an ordinary size room these could be very good. Anyway each speaker is matched and tested in an anechoic chamber by an engineer and given a certificate.
-, 视频播放量 7555、弹幕量 3、点赞数 78、投硬币枚数 12、收藏人数 20、转发人数 17, 视频作者 基础玩家数码影音评测, 作者简介 一档专门评测数码影音的评测类节目!,相关视频:蓝牙音箱 PK HIFI音箱,究竟谁的音质更好(现场试听),旗舰的魅力(KEF R11无源落地音箱评测),好声音都不便宜(自然声NS17无源旗舰HIFI音箱评测),听歌比较杂(交响 人声 小调 流行等),该怎么选音响设备?,CD和数播区别究竟有多大?,本年度 最强PK(B&W 飞艇五代 对比 灯笼)深入评测,惠威超级旗舰HIFI 15寸 4分频 音箱 F10...
www.bilibili.com
Have you heard of cryogenic loudspeakers ?
World Second Cryogenic Loudspeaker, after BORRESEN
PAIYON AUDIO, one the most advance loudspeaker manufacturer in China finally prove their technology not only in conventional loudspeaker, their are launching their Special Edition 3-way loudspeaker, the P82-SE (CRYO Special Edition version), gathering PAIYON know-how technology, advance components to build an ultimate high fidelity loudspeaker.
Paiyon P82-SE is a 3-way, sealed box loudspeaker. Each loudspeaker weight is 55kg, and height is 1062mm , width more than one feet, mark at 423mm and depth 546mm (feet dimension)
What is so unique about the Paiyon P82-SE ?
Titanium faceplate basket for HF Tweeter
Dual layer membranes (Made in Germany)
Special coated damping material
Premium quality Neodymium magnet
Large 6inch Soft-dome midrange driver (Patented Design: 201930275862.9)
Aerospace grade Y35 magnet
3" large reinforce voice coil
Alu-Magnesium + POM Polyoxymethylene Material Basket (Compared to many loudspeaker , they use low rigid basket and cause many distortion to the sound)
8inch mid-low woofer x 2
Alu-Magnesium Material basket
Ultra linear magnet curve technology
Large diameter magnet
Internal Cryogenic components:
Multi Gauge Pure Silver Solid Core + Monocrystal OCC speaker cable
Gold plated high purity OFC jumper
Crossover components
VIBORG AUDIO BP-604 Carbon Speaker terminal
First Impression
Paiyon P82SE comes with a large wood crate. It is heavy, each boxes weight at 80kg including the loudspeaker. It comes with a certificate signed by the acoustic engineer. The loudspeaker comes with a match pair serial number. The speaker indicates Serial Number with 00xxxL, and 00xxxR.
We hook up to the ToneWinner AD-3Pro. This is a pure class-A Integrated amplifier rated at 150watt at 8 ohms. Paiyon P82-SE original impedance rated at 4 ohms , recommended amplifier from 100watt to 300watt, sensitivity is 86db.
There is no problem for the AD-3Pro to match with the Paiyon loudspeaker, in fact, AD-3Pro is sufficient to drive Paiyon loudspeakers.
We hook up with BMC BCDC1.1 Top loading fully balanced CD Player, and a pair of XLR Cable to AD-3Pro.
Tonality was superb!
The soft dome tweeter delivers sweet, and smooth tonality sounding, high detail tha able to provide depth and large sound imaging.
Low frequency bass with layering
We can listen to a large amount of bass in every note
Overall Sound Imaging / Staging
Usually we need to adjust the loudspeaker placement correctly, then only we are able to get the nice precise sound stage. However, P82-SE is able to provide a good depth sound stage even if the whole setup is messy. Surrounded by many other speakers, both speakers are different distances from the wall , and different distances to the seat. P82-SE is able to playback very lively sounding music.
It shows that this loudspeaker's internal built quality is superb! The resonance, distortion are extremely low.
The whole presentation is very transparent, I was literally blown away by the performance of the P82-SE.
Conclusion
This is the first impression yet the loudspeaker hasn't run-in. After 300hours burn-in, let's see how it performs? We are looking forward on it.
Generally, we amaze with the sound transparency, very stable and extremely low noise floor. Easy to listen, and sound great!
Before delivery, all loudspeaker tested in Anechoic chamber. Once pass the test, engineer will provide a Certificate for each loudspeaker.
Specification
Frequency response: 40hz - 35,000hz
Crossover point: 400hz , 2700hz
Impedance : 4ohms
Recommended Amplifier: 200W - 400W
Weight per speaker: 55kg
Only 5pair, specially allocated for Malaysia market.
Limited stock with every matching pair serial number~!
Another level of ultra high fidelity sound~!
Please contact us for more details:
AUDIO ART SDN.BHD.
Warranty : 12 Years (144months)
