Can output impedance measurement/plot be added to the amplifier test repertoire?
M
mike7877
If the load impedance of a speaker/crossover is low and complex, I can see how a high D.F. (low source impedance) amplifier would be needed to drive something like that, and a D.F. of 20 would be sorely inadequate. Speakers I own tend to be pretty easy to drive, and my home brewed tube amps, with a D.F. of about 25, (high for a tube amp using an OPT) handle them just as well as my Bryston 4Bst bipolar transistor amp does if I don't ask the tube amps to play at powers only the Bryston can deliver. Bass seems similarly taut & bottomless with both amps on those (home-brewed) speakers. So, yes, difficult to drive speakers will need way more than a D.F. of 20 to do their best, no question there. There is no science denial here.
So if you were in the market for an amp, you'd find accurate damping factor specs a beneficial piece of information while doing research?
M
mike7877
I think if DF measurements are introduced, and along with the poorer results come explanations for why whenever possible (obviously sometimes no insight can be gleaned that hasn't already been from something else - situations vary) that people, myself included, could learn some things. I think that's why a good number of people come here - to learn things, share knowledge, and definitely to make better audio-related purchasing decisions. I'm extremely happy with my Topping G5 I got a few days ago. Thank you Amir and ASR, I will be forever grateful!
M
mike7877
A really good point is it's done for headphones, which are less likely than speakers to be negatively affected by output impedance.
Maybe the bad apples in the headphone realm are worse offenders, but offenders are everywhere!
Think about this:
If you could snap your fingers and instantly, every amplifier review on here now had damping factor measurements... what would you find out? How many of them would you be like "definitely didn't expect that result!"
"How the heck does this piece of carp have a DF of 1100?!
etc.
It'd be entertaining and informative
KSTR
Berlin, Germany
Output impedance and frequency response is not the same thing though.
Actually, that is frequency response of output voltage is not the same as frequency response of output impedance, or (the derived) frequency response of damping factor.
Overall the problem starts with damping factor specification being a marketing dept. invention, making it easy to achieve impressively large numbers which suggest a "much better performance" from a lay-person's perspective.
But the effective damping is more adequately expressed by damping = speaker_impedance / (speaker_impedance + amp_impedance). The microscopic ratio change when bringing amp_impedance closer to zero much better reflects what's going on. It even reflects negative output impedance which gives a over-unity value which means the amp damps even better than a full short. Damping factor cannot reflect that because it has a pole (division by zero, values reaching infinity) when output impedance approaches and reaches zero. As said, a nice marketing trick.
Reactions: ENG
egellings
It certainly wouldn't hurt to know that, even if only a minimum amount is specified. Again, most competent S.S. amps deliver way more than an adequate amount of D.F. I would certainly not use the 'more is better' approach regarding D.F. when looking for an amplifier. Other measurement parameters, such as SINAD, power output, etc., would be much more important to me. With tube amplifiers, I would pay attention to D.F. so that it meets some minimum amount, such as, say, 20, which works for my speakers. That could be too mushy for your speakers, I dunno. As it turns out, my circlotron-style tube amps are home brewed, transformers and all, and they show a D.F. of nearly 30. My speakers play well with that. Some very difficult to drive speakers would need the grunt afforded only by S.S. designs, and tube amps need not apply for a job in such a setting.
Doodski
How can the amp design D.F. be abused to create a extremely high D.F.?
fpitas
Northern Virginia, USA
No parts were abused, but Bruno's class D amps have tremendous negative feedback to acheieve that, among other things.
Doodski
The new designs are apparently capable of ~2 Ohms so how can anybody complain? The D.F. is a bonus result of the negative feedback loop? There was a urban legend of the damping factor circulating in the early 80s that a high rating would be better for large woofers. D.F. in general has been the sight of many a strange comment over the decades.
fpitas
The internet is a honeypot for bizarre ideas. The less they know, the more creative they get.
mhardy6647
Some (actually, I suspect, most) most of the hearsay, myth, fantasy, and urban legend that swirls around damping factor predates the internet www -- even before Al Gore was fiddlin' around with ethernet in the White House basement with alligator clips and an INTEL chip programmer. ;)
EDIT: Note to non-Americans, youngsters, hipsters, tripsters, and real cool chicks, sir -- Al Gore was reputed to have circuitously claimed to have invented the internet. This, too, is in about the same bucket of urban legends as are most of the Tales of the Amplifier Output Impedance. :cool:
fpitas
Yes, to some degree it's time-honored. But once it hit the internet it all ripened like a fine cheese.
SIY
Alfred, NY
You mean 2 milliohms?
Jukka
Output impedance of 1ET400A is 65 micro-ohm at 1 kHz (0.065 milliohm) per the spec. So if your cable has 20 milliohm resistance, amps output impedance won't mean a thing. Any effect in FR is easy to DSP away if it's bothering you. And output impedance is difficult to test because you need to know the exact impedance of cabling etc. That's probably why Amir hates testing it, but as I said before, if you want it, ask for it.
fpitas
Obviously, lower performing amps deserve more scrutiny in that way.
Mnyb
Sweden, Västerås
Yes the series resistance in passive xover components speaker cables the voice coil itself , i think between 20--100 is good enough for the amp its not anything like that driving the actual speaker cone ? Off cours you don't want the output impedance of an older tube amplifier or class D without proper feedback but there no need to chase excessive values .
realy high df migth have more application in subwoofers and active speakers where the amp is directly connected to the driver .
SSS
Germany
Right, DF is overemphasized since the resistances lie in the loudspeaker cable and the crossover network. And, DF is mostly necessary for the woofer. The tweeter does anyway what it wants to do.
egellings
I saw an amp, I think it might have been by Phase Linear, that touted a DF of 1000. That kind of DF can be gotten by applying a ton of negative feedback to knock Zo down to preposterously low levels, in the few milli-ohms region. Negative feedback lowers output impedance in an amplifier. The problem was that stability of the amplifier when driving difficult loads was compromised, all in the name of an outrageous number for the spec-of-the-month club publications. Such a low D.F. is simply unneeded in any home stereo application. I'm not willing to pay for it, nor sacrifice anything else in the amplifier design to get it. The abuse comes in the excessive exaggeration of some amplifier spec in the service of advertising BS. I think this specsmanship was spurred by the spec of the month club, where reviewers would gush that some particular spec, when pushed to extreme levels, would usher in Audio Nirvana (nervosa?). First it was DC to light frequency response, then slew rate, then power in outrageous amounts, then distortion readings in the nano-percent range, and I don't know what else.
Piere
Damping factor only tells you something about.......???? Yes educate me a bit :) And is there something of a magic number to strive for?
It's something of the past when tube amps did have high output impedances.
egellings
D.F. tells you about the ability of the amplifier to control the speaker's motions without the speaker having any say in how it moves. A low D.F. amp says, "Speaker, you are coming with me, do you understand?". Speaker says "Y-y-yessir!". With a low amplifier Zo, there is negligible voltage divider effect between the amplifier's Zo and the speaker's Z. As a result of this ratio, the speaker is unable to move the amplifier around by way of its back EMF, since a relatively high Z speaker is trying to push a near dead short around.
Piere
Apart from telling fairy tales to my speakers, what's the use of it then?
