Cable measurement
faheem
Last week, I changed cables, to the original hifiman which is longer. I noticed a difference in sound. There was a weird reverb and sounded a bit louder on one. Unsure whether it was my mind playing tricks.I did a quick oscilloscope measurement between the 2 cables, and then added a 3rd in the mix.
I used the built in tone generator @ 1khz and 2.5V. connected to tip and ring 2 on balanced jack and right and left on cup connectors. Is there anything in this and why would they be different?
solderdude
The Neitherlands
connector issue ?
Cable is broken ?
I would start by measuring DC resistance.
Cables cannot and do not sound different, Certainly not at 1kHz. The moment you get a measurable difference something is broken. Usually poor contact of one of the wires.
F
faheem
connector issue ?
Cable is broken ?
Yeah, I don't believe in sound changing due to cable, unless its broken. The question is which is broken, if all 3 are giving me that much of a variation?
The resistance were close, capacitance was different. I'll measure them again and get actual numbers.
solderdude
The Neitherlands
capacitance is of no influence (nor inductance) for headphones.
Only resistance is (when substantial in the common return wire)
Chances are the cables measure fine with a meter (and holding probes against the connectors) but the connectors may not make proper contact with the sockets. I regularly have these kind of issues which show themselves when wiggling the connector around.
F
faheem
I have a 2nd cable from the same manufacturer. Less than half the resistance. The original was 0.9 Ohm , second cable is 0.3 Ohm. I've tried wiggling connector, Haven't noticed anything. will stick with cable with lower resistance.
DVDdoug
A broken ground will create a "center-channel vocal removal" effect which will often leave some vocal reverb. It will also remove the centered bass and anything else that's identical and in-phase both channels. But the left & right channels should be identical.
Almost 1 Ohm is not normal but low resistance measurements are tricky and unreliable if you don't have a 4-wire Ohmmeter.
F
faheem
Curiousity got the better of me. I machined the jack plug off and found this.
The glue was holding it in place, rather than solder. Thanks for your help and @DVDdoug
solderdude
The Neitherlands
Nothing a new connector cannot solve fortunately.
At least the mystery is solved.
Intermittent and poor contacts can be a real pain.
