Agreed.The app needs to be stable and working first, then not require BS permissions.
Do you not use streaming services?
I'll have to test thatDon't you still get weird beeping when pausing/playing a track (not while it plays, but just before/after)? UAPP doesn't seem to solve it for me
Never noticed a beep but did have a whine. If it is persistent for you I would request a swap but I'm not sure it's a single unit error.Once I set up the EQ I wanted (standard), I just deleted the app. The EQ seems to persist regardless. Maybe I should replace my pair if you say you dont get any beeping sounds.
Do you still have these beeps after you deleted the Link app?Once I set up the EQ I wanted (standard), I just deleted the app. The EQ seems to persist regardless. Maybe I should replace my pair if you say you dont get any beeping sounds.
Variations is a very nice IEM, technically interesting with its DD+EST+BA combination of drivers. To me, the “nice & interesting” would be enough to keep it!I really want this one but I already have the Variations. The May comes with pre-installed and unremoveable filters inside which is nice since the ones for my Variations fall off occasionally. Think it's worth it? I also know that I can just add the cable to the Variations but if I get the May I can then sell the Variations since there wouldn't be any need to keep such an expensive IEM around.
Alleged distortions? Are there any measurements?Variations is a very nice IEM, technically interesting with its DD+EST+BA combination of drivers. To me, the “nice & interesting” would be enough to keep it!
That being said, wouldn’t the first question be: with the right EQ, can you get from MAY, the same, or a better, personalized “sound” you get with Variations? A second hypothetical question: if you were to add a FreeDSP cable to Variations (I know, more $$), could you EQ it to something even more satisfying for you, something you could not approach with MAY—whether it’s due to MAY alleged distortions, IMD… or simply a better fit for your ears…
Alleged distortions was poor wording as I haven’t seen any distortion measurement… I meant to say: it’s a question that needs to be addressed in a MAY vs. Variations comparison.Alleged distortions? Are there any measurements?
This is the Variations and May (standard). Both are really good. I kind of want the May anyway to compare.View attachment 337237
Most likely at 94 dBSPL.![]()
MOONDROP MAY DSP In-Ear Monitor | MOONDROP Official Website
moondroplab.com
Moondrop published their own THD measurements which show it to be very low. They do not disclose at what level it was measured.
Is this graph interactive? Can you provide a link please?
No. There are no links, the information has been generated by me through the graphs. But I attach the files with all the data, if you modify them you can open them with REW.Is this graph interactive? Can you provide a link please?
