Bowers & Wilkins 805S Bookshelf Speaker Review
Steve Dallas
A Whole Other Country
I bought a pair of Nautilus 805s in 2000 and still have them. I remember sauntering into a hifi store with a friend, so he could hear my awesome speakers. When the display 805s started playing, my heart sank. I looked at the back plate. Model 805S. At that moment, I knew B&W had taken a very wrong turn and may be lost in the wilderness for a long time. After hearing some new B&Ws, I'd say there are still wandering aimlessly. It's too bad.
Newman
This is a great point. On my Nautilus 804 owners manual they specifically state: "Aim the speakers straight ahead, do not toe-in". This would tend to lower the hot treble while simultaneously widening the dispersion.
Suggests to me that not only is the axial output flawed, but beamy off-axis too.
tuga
Oxford, England
To be fair most speakers are.
Speakers designed for use with no toe-in produce an up-tilting treble on-axis and the designers count on the increasingly beaming nature of tweeters to even-out the response at the listening spot.
This is the Dali Rubicon 8. In the horizontal dispersion plot the cursor (+) is at 45° and the speaker response is flat to around 15kHz.
https://www.stereophile.com/content/dali-rubicon-8-loudspeaker-measurements
renevoorburg
@amirm tested with the magnetic grill of the tweeter removed. B&W recommends to keep it on, for better dispersion (at least that is what the 805N manual states).
pierre
Switzerland
Here is a larger brother the Nautilus 802N. Data is from Harmann Gen 2.
Score improved significantly and with some light EQ this one will be good. Bass output looks great.
MZKM
Land O’ Lakes, FL
Here is what the 805S manual states:
The tweeter grilles are held in place with magnetism and any mishandling of the grille close to the tweeter may result in the grille being attracted into the tweeter diaphragm. For these reasons, we recommend that you leave tweeter grilles in place.
Here is what the manual for the Nautilus 805 states:
The tweeter is very delicate and its grille should be left in position for protection. For this reason the grille retaining ring is designed to provide the optimum acoustic environment for the unit and the response is less smooth with the grille removed.
I checked others, like the 805 Diamond, they all state a similar thing.
renevoorburg
You mean, similar to what the Nautilus manual says “less smooth response with the grill removed” or what the S manual says (nothing about the smoothness - i.e. dispersion? )?
The Nautilus has a crossover at 3 kHz, the S at 4 kHz (says amirm), would that explain that from the S on, smoothness is not an issue? Just guessing..
No. I did not touch the tweeter. I removed the grill over woofer.
You said magnetic grille was left off, and it looks like the woofer grille uses pegs.
Did you mean “left on”?
Ah, that was a cut and paste from previous review. :) I corrected it. Once again, I did not touch the tweeter or its grill. It is as you see it in the picture. I only removed the main grill over the woofer with mechanical pegs.
Thomas savage
The Watchman
uk, taunton
This must be like being back at Microsoft and being cross examined by European bureaucrats ha ha
Maiky76
French, living in China
Hi,
Back from a break, here is my take on the EQ.
Score with no EQ: 4.46
These speakers were highly rated back in the days but I always thought they were following some type of loudness compensation, "physio" in French vernacular. Now I know why.
The Vertical directivity is very narrow and not well controlled better seat at the exact height of the tweeter, far less critical on the horizontal plan :
The vertical 3D plot is quite telling:
EQ design, 6dB boost in the high Mids and LF, caution applies when listening at high SPL to avoid damaging the speaker.
Score: 5.91not great.
Code:
Type    Freq       Gain      Q
PEQ      56.0,     2.60,   1.05,...
PEQ     368.0,     0.69,   2.78,...
PEQ     678.0,    -0.76,   3.25,...
PEQ    2515.0,     4.70,   1.32...
PEQ    3741.0,    -2.42,   6.88,...
PEQ    2843.0,     1.43,   8.46,...
PEQ    4379.0,     1.29,   2.29,...
PEQ    9312.0,    -0.34,   2.28,...
EQed Spinorama
It is possible to partially compensate for the 1070Hz trough (+3dB, Q=7 Score 6.45) but I wouldn't advocate it as it looks like an interference mostly present in the vertical plan, really not straight forward.
Zoom of PIR - LW - ON
Regression - Tonal, much flatter
Radar plot comparing the EQ and the bare speaker, interesting gains:
The rest of the data is attached.
Darwin
The brand new 60X series have a better crossover, so I would like to see that measured to see if they now go for objectively good measurements.
I have the 25th anniversary 606 that just came out. Love them. More than my Revel M16’s. They are a little clearer with more detail. Even worse for the cool kids on Internet forums I got them at Best Buy.
tuga
Oxford, England
I would have thought that What Hi-Fi? was mostly read by audiophile newbies and regular consumers, hence the star rating.
Not that I would recommend any magazine but WHF? is for particularly undemanding buyers...
fred_64538
The B&W's 800 series speakers may not be rarest or most acoustically pristine.
But, I must admit they are beautiful objects.
They are a Porsche 911. Their success has made them vulgar.
