Thesoundof
- Joined
- Nov 19, 2019
- Messages
- 5
- Likes
- 11
ATM.trialing the Bluesound Powernode N330 and as a consequence dropped into armirm's thread of the Bluesound NODE "2021" and came to wonder if the DAC in the N330 performs as flawed as in the Node, since both consist of PCM5343 I assume it would be the case.
Can someone test the performance of N330 output using toslink from a computer as source? As a side note, would it be possible to test in BlueOS - Radio Paradise with MQA enabled VS normal Radio Paradise stream (For more INFO) and Qobuz/Tidals performance through BlueOS VS Optical? How does the headphone output really perform in N330?
Setup:
Qobuz(wasapi exclusive)/PC/USB/SMSL M500 DAC - LineMagnetic-217IA 300B - Straightwire Black Silk speaker cables - ProAc studio 125 speakers
VS
Qobuz(wasapi exclusive)/PC/Toslink/Bluesound Powernode N330 - Straightwire Black Silk speaker cables - ProAc studio 125 speakers
From what I can tell so far the LineMagnetic-217IA 300B Tube amp with SMSL M500 smoothens out bad recordings better and has somewhat better overall "contrast" though it is difficult to distinguish any clear drawbacks with the Powernode N330 other than that the setup looks extremely minimalistic and medicore recordings performs worse. IMO.with good recordings there seems to be no clear issues of separation, dynamics, soundstage, bass, mid end or high end as expected from this "all in one component" that consumes about as much as a LED bulb. The price difference regarding purchasing, maintaining and power consumption of the Tube amp doesn't justify the audio differences there may be. So either new technology is on it's way to "break the audio physical law", both stages are medicore or SMSL aint performing better than Powernode's DAC.
NOTE: 0 problems installing and using the BlueOS app on iPhone or logging in/adding any services.
Setup:
VS
