RadioBuddha
- Joined
- Jul 1, 2021
- Messages
- 75
- Likes
- 17
Depending on your source you can always bypass the Play-Fi app. Spotify direct works fine, as does the Amazon app. For Qobuz and local files I use Audirvana.or Bubbleupnp. At this writing I'm only using Play Fi for XM radio and have no problem.
Spotify Connect, that checks one box, does it have Airplay, I will check the website, and what internet radio database does Play Fi use? But here is the question, how do you use Audirvana and Bubbleupnp, how does that work? I thought you are limited to the OS of these internet streamers, can you do the same thing with the Yamaha WXC-50?
If you are using Audirvana with the Paradigm PW Link, could you also use Picoreplayer and the Logitech Media Server with the Paradigm?
