RadioBuddha
- Joined
- Jul 1, 2021
- Messages
- 75
- Likes
- 17
I'm not sure how many updates a unit gets makes it good, but okay. I'm going to assume you have a fancy remote and display that you can see across the room to know what you're selecting. I use a iPad and stream from my NAS or from Apple Music and have a great display that IO can see. I've also used Tital and Amazon music the same way. I just don'gt see any value in this device.
I'm not certain either, the Wiim Mini or the new Wiim Pro that will be arriving in the fall could fit the bill for what I am looking for but heads up, here is the new Bluesound Powernode Edge:
Am I correct that this Edge does not have any analog inputs? If I am just getting a low powered Wiim Mini, I will just keep my current ancient integrated amplifier but if I were to switch to this, I have a bunch of RCA analog inputs through an AV switcher thus I would need at least one analog input, I don't see it here, unless there is some adapter that could be purchased, anyway, thoughts on the Edge?
Update: OK, it does have a 3.5mm analog input, so I gather I could get a 3.5mm to rca jack wire to connect the switcher.
