dshreter
- Joined
- Dec 31, 2019
- Messages
- 808
- Likes
- 1,262
Sorry typo. SPOTIFY connectI don’t think the NODE supports Sonos Connect.
The NODE (N130) was released in July this year so most likely 6 to 7 months with it, not 1 yearI had the Node fo almost a year now. Tidal connect works great and this was my main reason fo buying. I also can not tell difference between internal vs external DAC via optical out. Pretty happy user except I wish USB out worked. Bluesound said update coming before 2022. We will see
no worries, you couldn't have known that.Well, sorry I pointed you toward this thing. It clearly doesn't do what it's advertised to do. Sad!
Denon’s HEOS link 2 does this for around $350.00 and has a subwoofer out. Can view at Crutchfield.This entire discussion shows how Bluesound has found a market niche -- and why it would be great for them to have some competition!
The Node series (the old 2, 2i, now just Node) fill a gap: a single, simple product that provides out-of-the-box streaming, with native support for a large number of services and decent, supported software with easy remote control (the BluOS app). The DAC is "good enough" for most people; for the fussier, coax and optical outputs and USB coming soon (we hope) to run to a better DAC.
Alternatives? Well, the discussion above mentioned a few but there are "gotchas". There's the Raspberry Pi solution, but you have to figure out how to put it together, you have to pay extra for subscription that reportedly is not all that great, and it's unclear what the remote control option is. (I suppose there is one, but I've never heard it described.) Seasoned computer hobbyists may have no trouble with any of this, but how many others want to try it?
So the competition needed is a "raw" streamer, basically a Node minus the DAC, analog outputs and controls, and subwoofer out -- just the streamer part with digital out. That would knock a significant chunk off the price. Come on, Bluesound -- or someone else.
Allo Digital with Piano 2.1 DACThis entire discussion shows how Bluesound has found a market niche -- and why it would be great for them to have some competition!
If they only added XLR out and a better DAC.This entire discussion shows how Bluesound has found a market niche -- and why it would be great for them to have some competition!
I believe Node supports Spotify connect.Sorry typo. SPOTIFY connect
got feedback from WiiM that "it's a known issue" that they are working to fixing it in the next firmware update. Let's wait then...[...]
Anyways, I've wrote them asking what's up with that Tidal "Connect", why it doesn't work. Who knows, maybe I am really doing something wrong.
On the USB Output : There's speculation it is a Hardware problem with the Node (3) N130 , not firmware.
Expired/ invalid certificate?The other issue is that when I try to access the Blusound forum I receive the warning "Potentially malicious software ..."on both Firefox and Chrome. Any idea what that may be?
What do you mean by subscription?There's the Raspberry Pi solution, but you have to figure out how to put it together, you have to pay extra for subscription that reportedly is not all that great, and it's unclear what the remote control option is. (I suppose there is one, but I've never heard it described.) Seasoned computer hobbyists may have no trouble with any of this, but how many others want to try it?
