Best diy speaker kit
Nedjohnson
Hello to the community. Any recommendations for a 2 or 3 way speaker kit? Will be paired with ICEPower amp, whatever wattage needed. Or something similar if anyone has recommendations. Box dimensions will be about 22 in(56cm) tall by 12 in(30.5 cm) wide by 17 in deep. Dimensions can change by +\- 2 inches. Needs to include components for or prebuilt crossover. Looking to spend $1000-1500 per pair, going for best all around value for complete sound. Thank you for any input.
I would recommend the Satorique S1. With the two tweeters available you can influence the price.
Already 2 or 3 comparable threads here. Here is one…
Reactions: MAB
Thanks for pointing that out
You have not indicated the size of your room, the bass capability necessary, any restrictions on placement nor any personal preferences that you might have. This kit might be acceptable ... or might not.
https://www.madisoundspeakerstore.com/3-way-speaker-kits/sb-acoustics-gema-3-way-speaker-kit-pair/
Flat-packs are available should you so desire:
I have not heard this system, not do I know anyone who has. There is, however, a thread on this speaker here at ASR:
Good luck! ;)
Jim
Check this one out…
A few measurements and a lot of superlatives so like a lot of youtuber projects. If you want to do open baffle seriously, need to consider Linkwitz Labs and gainphile’s designs. Some of the latter ones might pass the WAF in my house!:)
My wife liked the Linkwitz Orions a lot, and has been okay with both the lxmini and lx521 in our living room, so long as nothing else is visible!
