Nedjohnson
- Joined
- Sep 5, 2024
- Messages
- 18
- Likes
- 5
- Thread Starter
- #21
Got it, great info. Really appreciate your time. I go ahead and give it a shot! I wish I could just use normal amps but it seems like everyone loves the nostalgia of tube amps because the cabinet design is similar to vintage designsYeah, I don’t recommend OJAS, but was pointing out that they build a box around the Ceiling speaker I recommended.
It’s easy enough for the furniture builder to take that JBL driver and put it in a box. That’s the whole point. OJAS cuts away a lot of the wave guide which you probably shouldn’t do.
But it means that the driver itself is pretty solid and you just need to put it in a box with the right amount of volume.
@Nedjohnson
The elekit is great. But definitely need something efficient like the driver I suggested. Not sure if there are other choices, since Fostex is pretty good too.
The problem with Fostex is just that the bass response won’t be there.
