BerryBak Bea1 Digital Audio Receiver for Home and Car with Ldac
Audiomaniac3
Hello everyone,in this video:
I got a digital plug and play audio receiver for home and car,which has an integrated USB C connector for power and signal transmission,as well as Bluetooth 5.3 with the most advanced audio codecs at the moment,Ldac and Aptx lossless, unfortunately,my phone does not support the Aptx lossless codec.
The audio receiver comes with two antennas of different lengths and an optical cable.
The ES9018K2M DAC with a maximum sampling frequency of 96Khz/24bit and standard RCA terminals are used for analog audio output(2V rms).
Thanks to the presence of an optical output,the audio soundcard can be used as a bridge to transmit a digital signal from a PC or phone via USB/Bluetooth to a receiver/amplifier with an optical input,and can also be used as a Bluetooth audio receiver for a car with aux input.
Bluetooth and USB connection can be used at the same time if needed,priority will be set on Bluetooth,if Bluetooth device will play music Bea1 will switch to Bluetooth immediately and when music stops back to USB audio in 6-7 seconds.
BerryBak BEA1 is a universal device with a wide range of possibilities.
Link to BEA1:
Reactions: yo!
